S - Audid
20vT - tuuning
Audi 20v 2,5L strokeri ehitamine
[quote][i]Algselt postitas: kaharm[/i] JE Piston set for Audi I5 20vt, available in multiple configurations: [b]$1,195.00 [/b] 4V 5CYL, 83mm bore, 92.8 stroke, 144mm rod length, 20 mm pin, 8.5:1 compression Dished [b]4V 5CYL 83mm bore, 95.5mm stroke, 144mm rod length, 20 mm pin, 8.5.1 compression Dished [/b] 4V 5CYL 82.5 mm bore, 86.4 stroke, 144mm rod length, 20 mm pin, 8.5:1 compression Dished 4V 5CYL, 82.75 mm bore, 92.8mm stroke, 144mm rod, 20 mm pin, 8.5:1 compression Dished Custom, whatever you can think of! We have some models in stock, inquire for availability, some sets may require 3 week lead time. http://www.034motorsport.com/product_info.php?cPath=28_63_73&products_id=110 Kas 3B plokk allub 83mm puurimisele ja uuele vändale samahästi kui AAN plokk? JE kolbe saab kuskilt ilmselt odavamalt? Kas peale saalede kulumise, kolbide hinna:) on veel miinuseid. [/quote]
S - Audid
20vT - tuuning
22
35.1%
64.9%
