Diesel power
Mure 3.0TDI pihustitega
[quote][i]Algselt postitas: Kert85[/i] Ei taha teada, mis selline aparatuur maksab, et nendele "remonditud" pihustitele uued "väärtused" mõõta. Injector Quantity Adjustment (IMA) and Injector Voltage Adjustment (ISA) These values represent the behavior of an injection valve (Piezo Injector). Caused by manufacturing tolerances the injectors have a unique behavior and get divided into separate classes. In combination with the automatically determined learning values of the engine control module the pre- and post-injections are being calculated individually for each valve. The behavior of an injection valve is also mileage dependent, so a valve with e.g. 10000 km has a different behavior then one with 70000 km. The control module determines these automatically while driving so the learning values change against the mileage. When altering one of the following values the learning values are being reset because the ECU thinks you are adjusting a new valve. Kui see pihusti nüüd taastada, siis mootoriajule ikka selgeks ei saa niisama teha, kuidas seda pihustit juhtida õigesti. Mootoriaju mõõdab peale igat töötakti hooratta kiirendust ja määrab korrektuurid vastavale pihustile, aga sedasi ta selgeks ikka ei suuda terviklikult õppida, kuidas suvalist pihustit juhtida. [/quote]
Diesel power
22.7%
77.3%
