KsenoonE
 postitati 17.08.11 10:36
Algselt postitas: Black
Algselt postitas: KsenoonE
Kuidas Audi A8 OEL tuld saab resettida. Homme plaan õli vahetada ja tahaks seda ka eest ära saada.
Vaata siit algusest kohe Erki posti.
Kas ilma kaablita ei saa?
 postitati 17.08.11 05:33
Edit: ahjaa, siin teemas ju ka ülalpool olemas.
KsenoonE
 postitati 16.08.11 23:17
itsiim
 postitati 23.11.09 20:22
Äkki saaks ikka kuidagi sellest lahti? Peksaks näiteks selle väikse display kiviga sodiks??
 postitati 23.11.09 12:03
Algselt postitas: itsiim
Kas ikka ei oska veel keegi öelda mida tähendab In-0??
Seda ehk, et kõik on korras, pole vaja niisama süüdet sees hoida. Keera käima ja sõida. :)
itsiim
 postitati 23.11.09 11:31
automees6
 postitati 12.07.09 20:57
Sihuke hea õpetus vag-comiga nullimiseks. Ross-Tech i lehelt vist. Ja andmed mida millal teaha saab Autodatast.
1998 and Newer:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 02
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of 0 (zero)
[Test]
[Save]
Note: It is normal for the display to show something like "--/--" instead of an actual distance/time to service after resetting until you have driven some distance.
Pre-1998 models ... or if Channel 02 is not available:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter the correct channel from the list below in "Channel Number"
[Read]
Enter the "New" value of from the list below.
[Test]
[Save]
Channel 05 should be the distance until the next Oil Service.
It is in thousands of kilometers. Let's say you want the Oil
Service light to come on in 5000 miles. That would be 8000 km.
Put the value 8 into channel 05. The "standard value" used by the US
dealers would be 12 (7500 miles).
Channel 06 should be the distance until the next In-1 Service.
Same units as above. Standard value would be 24 (15,000 miles).
Channel 07 should be the time until the next In-1. In-1 lights
up based on time or distance, whichever comes first. This is in
10's of days. Standard value would be 36 for 360 days.
Channel 08 would be time until the next In-2. In-2 is based
strictly on time. Standard value is 72 for 720 days (about
two years).
lunatic
 postitati 12.07.09 19:29
Mingi seletus on näiteks siin (vist V6 mootori kohta). Eks peab veel otsima ja täpsutama, need jutud on kirjas küll internetis ja kasutusjuhendis.
Lumekass
 postitati 12.07.09 17:45
Kui kellelgi on teavet, mida nende tulukeste ilmumisel ära peaks vahetama või üle kontrollima, võiks siia kirja panna. Sest vilkuma/põlema hakkavad nad kindlal põhjusel :cool:
PS. OIL märgutuli on ilmselt kõigile arusaadav :)
erki.t
 postitati 12.07.09 15:59
Algselt postitas: Skeldo
OEL - Õlivahetuse aeg. Esimest korda annab endast märku 1000km enne vahetust ning mingi aeg enne kilometraasi täis saamist jääbki põlema. Igal Õlivahetusel lükatakse 15000 edasi.
Palun täiendage kui leiate, et midagi valesti või puudu.
Tegelikult ei lükata kõigil kirvereeglina 15 000 km vaid ikkagi vastavalt konkreetsele isendile ;)
itsiim
 postitati 12.07.09 15:21
Minu 94a. A6-l Kustutati IN1 ja IN2 just ära. Nüüd avastasin et kui niisama süüdet sees hoida siis ilmub välja keegi IN.0. Kes see on?
Vaarao
 postitati 03.03.08 19:22
Minu a4 95a ei saa kuidagi ise nullida . Ainult teeninduses.Pole neid nuppe mida tõmmata või lükata.Minu teada ei saa ise nullida 95-98a A4 -si. Õli vahetust saab panna kuni 15 kilo.
juks11
 postitati 03.03.08 13:29
Juhiks tähelepanu veel sellele, et 2000 ja uuematel autodel hakkas ka õlikvaliteet mängu tulema ning tulenevalt sellest on vaja ka õiged nullimised teha.
lukas
 postitati 03.03.08 12:52
Kuna ka C5 kerega A6-ed on jäänud juba suht vanaks ja palju kindlasti teeninduses enam ei käi siis ka A6 C5 service nullimine.
Teemo
 postitati 03.03.08 10:08
Algselt postitas: zayetz
Servisenäidiku nullimine A4 & A6 (kõik aastad):
* Keera süüde välja
* Vajuta ja hoia all (EDIT: või siis tõmba ja hoia) displeist vasakul asuvat nuppu ning samaaegselt keera süüde sisse
* Kiri "OIL" ilmub displeile
* Tõmba välja ja hoia displeist paremal asuvat nuppu kuni kiri kustub
* Displeil peaks olema kiri "---"
Kui ülalkirjeldatud meetod ei toimi, siis alternatiiv on alljärgnev:
* Süüde väljas olekus vajuta paremat nuppu
* Keera süüde sisse ja tõmba vasakut nuppu
* See peaks kustutama hoiatuskirja
Muidu on kõik hea, aga kuskilt oleks vaja leida täpsed aastaarvud, sest kõikidel mudelitel see siiski ei tööta.
Umbes kümne auto kogemusel võin öelda, et c4 kerega A6-l ei saa ilma Vag-Com'ita ning sama lugu ka 95-96 a4-ga.
zayetz
 postitati 03.03.08 08:44
* Keera süüde välja
jõuvanker
 postitati 03.03.08 07:58
Siia võiks lisaks kirjutada nullimise/kustutamise juhised, nii kellablokil nuppudega kui VAG-COM´iga.
Skeldo
 postitati 03.03.08 07:29
Seoses sellega, et foorumis tihti teemad mida tähendab kiri In2 ja OEL jne teen teema kus panen kirja mida need tähendavad.
IN1 - inspection 1 - 30,000 km või 365 päeva.
IN2 - inspection 2 - 30,000 km või 730 päeva.
[PHP: 54.3% - SQL: 45.7%]
