Elektroonika
Mida tähendab läbisõdunädikul vilkuv 'InI'
[quote][i]Algselt postitas: Kirsa[/i] Ehk siis järgnevaid asju tuleks teha? Väljavõte 12v.org lehelt: Service every 15,000 miles / 24,000 kilometers or 12 months Change engine oil Change engine oil filter Replace climate control dust and pollen filter Check engine coolant level Check power steering fluid level Check brake fluid level Check transmission fluid level Check electrolyte level of battery Check brake pad and rotor thickness Check CV boots for cracks Check windshield washer fluid level Check air pressure in spare tire Inspect engine for leaks Clean guide rails of sliding roof and lubricate with silicone spray Check water drain valve in plenum chamber Check engine idle speed (not for models with ODB) Check OnBoard Diagnostics (OBD) fault memory and clear if necessary [/quote]
Elektroonika
38.4%
61.6%
