Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi RS6 2002 888 MED, kas keegi teab midagi selle auto minevikust? OSTETUD
Pealkiri: Audi RS6 2002 888 MED, kas keegi teab midagi selle auto minevikust? OSTETUD (Vastuseid: 21 | Vaatamisi: 4227)
Audi RS 2
Registreerunud 01.10.02
Auto: Audi C5, Ford F-150 5.0
postitati 23.04.11 10:41 Tsiteeri
Tere,
Kas keegi teab midagi selle auto minevikust, tema hoidmisest jne?
http://www.auto24.ee/used/767021
Ette tänades
pillekas
Registreerunud 12.03.10
postitati 23.04.11 12:59 Tsiteeri
Vaevalt,et keegi sellest midagi teab!Sest see on jaapanist toodud.
A4TQ
Registreerunud 24.07.03
Auto: SQ7, 911
postitati 23.04.11 16:08 Tsiteeri
Algselt postitas: pillekas
Kui ikka ei tea siis ei ole mõtet sõna võtta.
See auto on toodud 2007 kevad Saksast. Abt soft on saksas paigaldatud ja minuteada ka tehn passi kantud.
Inimene kelle auto see on oli autoremondi töökoja omanik ja autot on korralikult hooldatud. Suurema asjana on Eestis paigaldatud Bilsteini reguleeritavad amordid.
juks11
postitati 23.04.11 16:57 Tsiteeri
Ka mina tean seda autot juba aastaid ja seda Eestis, mitte Jaapanis...
Rom
Registreerunud 28.05.05
Auto: C6 3.0TFSI S-line
postitati 23.04.11 17:20 Tsiteeri
Kas see on see sama, mis korduvalt käigukasti jamade tõttu audihoolduses käis?
juks11
postitati 23.04.11 17:37 Tsiteeri
Algselt postitas: Rom
Ei ja ma nagu ei teagi ühtegi RS6'te mis korduvalt kasti jamadega käinud oleks, paaril oleme kasti remondi teinud ning ühel midagi oli aga ma ei mäleta mis teema seal oli.
Ning lisaks liigub veel üks valejutt ühe RS6'e kastijama kohta mida on meilt paar korda küsitud aga meie sellega seotud ei ole.
pillekas
postitati 23.04.11 20:40 Tsiteeri
Algselt postitas: juks11
Huvitav huvitav,siis need kes seda autot müüvad,ei tea sellest vist midagi!Sest ühes kuulutuses oli kirjas,et Jaapanist!
olbert
Registreerunud 13.01.06
Auto: Golf IV 1,9TDi 4Motion Variant
postitati 24.04.11 06:25 Tsiteeri
Eestis ongi nii, et kuulutuses on kirjas, et otse saksast aga tegelikult vurab juba päris pikalt meie teedel. Olen ka ise kohanud selliseid tegelasi.
Päikest
Kuule mees, ega sa rahvastepalli ei mängi, kus sul mitu elu on!
www.alunaut.ee kõik alumiiniumi tööd (tegemist siis merealumiiniumiga)
ICE
ac aasta auto 2006 võitja
Registreerunud 27.09.02
postitati 24.04.11 07:00 Tsiteeri
See "otse jaapanist" võib antud auto puhul olla seetõttu, et autod.ee toob palju masinaid japsist ning ehk kasutavad müügikuulutuse tegemisel mingit kindlat tekstipõhja, kus see siis on jäänud muutmata.
Joel
postitati 24.04.11 17:38 Tsiteeri
Igal juhul on selle auto hind tänase seisuga juba vähemalt 7-8 kuud püsinud muutumatuna. Olen seda masinat ikka ajaviiteks auto24s jälginud. Kuna hind ei sisalda käibemaksu, siis on see üsna krõbe, samas Bilsteini coilide installi operatsioon on juba ette ära tehtud, sisu on kena ja inimliku hinnaga sedaane Saksast leida on pea võimatu. Ehk kaup tundub iseenesest adekvaatne.
Competition
Registreerunud 12.01.04
Auto: Audi S6, 250KW, 2001.a.
postitati 25.04.11 07:59 Tsiteeri
Hind ongi muutumata, kuna tegu peaks olema panga varaga:)
Seega on pank hinna ette andnud ja sealt naljalt alla ei lasta:)
veekaheksa
Registreerunud 07.09.03
Auto: A4 TDI quattro, S8 40V
postitati 25.04.11 08:29 Tsiteeri
Ka pank laseb ilusti alla. Ärgem nüüd teda nii kõikvõimsaks kah maaligem.
pprz
postitati 25.04.11 10:50 Tsiteeri
Panga eesmärk ei ole ebalikviidset vara koguda ja hoida, vaid sellest lahti saada. Vajadusel nõuavad viimase auto kasutaja käest vajaliku summa sisse.
AronL
Registreerunud 07.09.08
Auto: M140i xDrive
postitati 25.04.11 11:07 Tsiteeri
See juba tükk aega müügis olnud ja kui sellele palju huvilisi pole olnud, saab sealt tõenäoliselt päris kenasti hinnast alla, tuleb vaid pangaga suhelda ja omapoolse pakkumise teha.
100
Aeg maha
Registreerunud 12.04.10
Auto: 100
postitati 25.04.11 19:04 Tsiteeri
Seega talve läbi vaid seisnud?
Audi RS 2
postitati 02.05.11 19:25 Tsiteeri
Tänud kõigile, kes olid abiks.
Lasin auto revalis üle vaadata, nipet näpet leidus ikka. Kuna aga auto on seisnud pikalt, võib sealt kõike ette tulla.
Igaljuhul otsustasin auto sealt ära päästa, eks ole näha kas ta on ustav ja teenib mind kenasti.
Imelik on see, et olin siin klubis üks esimesi liikmeid, kuid millegi pärast on mul piirangud teatud teemadesse sisenemisel, muidu läheks üle klubiliikmete autod postitusse ja kirjutaks seal autost edasi, kuid kahjuks ei pääse...
A4TQ
Auto: SQ7, 911
postitati 02.05.11 19:31 Tsiteeri
Klubiliikmeks saamine
Joel
postitati 02.05.11 19:33 Tsiteeri
Oled tõepoolest väga ammune foorumiliige (38.), kuid ilmselt vahepeal väheaktiivne olnud. Foorum on vahepeal tehtud kahetasandiliseks - huvilised ja MTÜ Eesti Audi Klubi liikmed. Täpsemat infot saad siit - > http://foorum.audiclub.ee/viewthread.php?tid=53696. Oled oodatud klubiliikmeks.
Palju õnne ja loodame, et masin kestab kenasti. Tule mõnikord näita kogunemisel ka.
postitati 02.05.11 19:39 Tsiteeri
Algselt postitas: Audi RS 2
Loodetavasti ei midagi tösist nipet-näpet.
Masin oli vist töesti kaua seisnud, sest mootoril oli näha alum. oksiidikihti juba, mootor oli ka üsna määrdunud, salongis samuti omajagu kulumismärke, kuid need vast tüüpilised (tulede lüliti ümbrus jne).
Sai seda reedel A8 körval vilksamisi kiikamas käidud.
Edu paugutamisel ;)
Raigo22
Registreerunud 02.10.06
Auto: Audi A6
postitati 02.05.11 20:21 Tsiteeri
Kui saladus ei ole kas sai antud auto pealt midagi alla ka veel?
58 160 982
Audi RS 2
postitati 04.05.11 09:51 Tsiteeri
Hinnast nii palju,
Tegin Revalis leitud puuduste põhjal kalkulatsiooni, mis nende likvideerimine maksma läheb. Esitasin selle eelmisele omanikule. Leppisime kokku, et kui 50% selle kalkulatsiooni maksumusest hinnast alla saab, siis teeme tehingu ära.
Nii on eelmisel omanikul südametunnistus puhas ja minul ka kergem.
Eks loomulikult, tõeline seisukord selgub lähi kuudel. Auto pikalt seisnud ja kahjuks mootorisse ja käigukasti sisse ei näe.
Aga leian, et sellist autot hoida ja sinna panustada on väärt investeering. Loodan, et sedaan RS-ide hinnad on hetkel oma madalaimal tasemel...
Aga see ainult minu filosoofia.
Tervisi
Auto: 6x4x4
postitati 04.05.11 09:55 Tsiteeri
Parandame Sinu filosoofiat. Sa mitte ei investeeri autosse vaid oma enesetundesse ja naudingusse, mis see isend oma olemusega p*rsetunde kaudu tekitab :D. Igal juhul väärt soetus.
[PHP: 16.7% - SQL: 83.3%]
