Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Turbo geomeetria juhtimine rõhuga.
Pealkiri: Turbo geomeetria juhtimine rõhuga. (Vastuseid: 10 | Vaatamisi: 3815)
Samzik
Registreerunud 12.09.04
Auto: Passat 1.9/96kw 4WD 2004, audi 90 2.1/134kw q 87A
postitati 24.03.11 13:15 Tsiteeri
Kas keegi on reaalselt ka kasutanud sellist asja?
Tean, et seda on tehtud bmw peal ja on õnnestunud mehaanilise pumbaga. Hoiab stabiilset rõhku.
Kas keegi on sellest midagi veel kuulnud? Saaks ka päris vanade aparaatide puhul vnt d kasutada.
Sobilik pidi olema wastegate membraanklapp. Mis nügib ennast rõhuga.
Rain.
Pakkuda uus Haldex õlipumba elektrimootor. E parandan mittetöötava mootori+uued tihendid. Mbl: 55 55 88 55.
scottimees
Registreerunud 22.03.06
postitati 26.03.11 18:05 Tsiteeri
Proovinud küll ei ole aga ma ise olen ka selle peale mõelnud :D On paar pisiasja mis panid mõtlema. Wasgate membraanil on jäik vedru taga ja on lühike käik, geomeetria tahab ikka tublisti liigutamist. Kui kasutada pika käiguga membraani, siis peab seal sees olema lahjem vedru ja siis ta rakendub madalama survega. Kogu sisselaske süsteem (kuuler, lõdvikud ja värid) peab siis olema tugevdatud, kuna pöördeid maha lastes kui süsteemi jääb rõhk midagi võib lõhki minna, kuna õhul pole kuhugi minna. Kõik on nuputamise värk :) Kui asi õnnestub siis oleks @wesome!
Samzik
postitati 27.03.11 21:27 Tsiteeri
bkiw offiga saab turbo ette rõhu tagasi lükata, aga diislil pole segu siibrit seega... ja turbo kiirus kukub alla vastu rõhuga nagunii kui gaase peale enam ei tule. Ning lisaks lükatakse geomeetria kah maha täiesti enne rõhu kadumist. Seega siin ma probleeme ei näe.
paranormaalne
Registreerunud 23.08.04
Auto: AAN+3B+AEL+AAN+AAN+AAN+AAN+ABY
postitati 28.03.11 13:37 Tsiteeri
Mõelge parem vana kooli (vaakumiga töötava) püsikiiruse hoidja aju ja pumba peale. ;-)
__
Andres
värdsõnade leksikon - kellablokk, varjant, igastähes, nukvõll, org. eesliide - orgaaniline jagaja?, velüür, bronks, gardaan, polüretaan, millekagi, ütlematta, värvimatta, hooldamatta, tahtmatta, vahetamatta, katusetta, ostmatta, õieti vs. õigesti, kvall, sürpriis, kahedeist, oksion, pumb, doll (mõõtühik), saabgi, kellegile, tänamattu, algorütm, roolilätt, rädikas, milleGIGA, paraleel, didident, laadia, oktsion, kabasnik, pagaaznik, toonor, sumbuti, saaleviga, airbäg, bäg, gartaan
Samzik
postitati 28.03.11 16:28 Tsiteeri
Kas see sudab rõhku hoida? Sest vaakumpumpasi on erinevaid. Palun seleta mida oma postitusega mõtled.
scottimees
postitati 28.03.11 19:36 Tsiteeri
Algselt postitas: Samzik
Geomeetriaga masinatel lükatakse jah geomeetria maha, kui lased gaasi maha aga kui on geomeetria põhjas, mis siis juhtub? Ütleme kiirendad põhjagaasiga ja vajutad siduri alla, siis puhub ju kõik asjad lõhki...ma arvan
Samzik
postitati 29.03.11 13:27 Tsiteeri
Koormus kaob ju tagant ära ja gaase ei tule peale miks peaks? Ja ülerõhu lahendab blow off, mida ei pea atmosfääri paiskama, vaid võib saata turbo ette.
scottimees
postitati 16.04.11 06:18 Tsiteeri
See kisub vaikselt mõttetuste hulka... Olgu parem nii nagu, kõik toimib ja kõik on timmis :)
Maku
postitati 16.04.11 07:45 Tsiteeri
Samas mõtlemine pole keelatud, samuti nende mõtete arutamine. Mõtlev inimene on toimiv inimene.:)
scottimees
postitati 23.04.11 06:38 Tsiteeri
Seda küll. Aga samas ma arvan, et sakslane on seda 10 korda mõelnud ja järgi proovinud. Saksa autode puhul on alati nii, et mõtled oma süsteemi välja, mis peaks olema hea ja lihtne, siis tekkivad sellised nö "mustad augud", sellised nõksud ja kohad kus see uus süsteem "ei oska olla" ja kui mõtled lahenduste peale, muutub asi nii keeruliseks, et ise ka ei usu ja lõpude lõpuks jõuad samale kohale kust alustasid - ehk originaal süsteemi taolise või täiesti identse süsteemi peale.
Tegelane5
Registreerunud 26.09.05
postitati 25.04.11 08:19 Tsiteeri
Algselt postitas: scottimees
Kui labad laiali siis peaks kõik olema tavalise turbo olukorras?!
http://paultan.org/2006/08/16/how-does-variable-turbine-geometry-work/
Oma TD sidrunil katsetaks küll asja ära kunagi, kuigi karta on et ennem annab seal midagi muud otsad kui turbo. :o
[PHP: 21.1% - SQL: 78.9%]
