Pealkiri: Pidurid (Vastuseid: 0 | Vaatamisi: 6540)
Maku
postitati 02.10.10 20:09 Tsiteeri
Pidurid
Algselt postitas: Maku
S4 Tuning - Brakes
The standard S4 brakes could be better. They fade after just one big stop. This can be largely sorted with the use of some high quality performance brake pads. If this still isn't enough for you the next step is to increase the diameter of the brake discs. There are a number of ways of doing this and all methods require upgrading the wheels from 17s to 18s. HiSpec make a kit for 1500quid and this should be up to the most extreme track use. There is also an option of fitting the B7 RS4 brakes which use 8pot Brembo calipers. Speak to MRC for more details.
For the rear brakes a easy option is to get S8 caliper brackets which gives the ability to fit S8 discs. Calipers are extremely long lasting with the only really problem coming from the ABS electronics. The ABS circuit board can be reconditioned for a few hundred quid but if you want to replace the complete module this will set you back about a grand.
Lisaks:
Pre-facelift std = 245 x 12mm solid discs
Facelift std = 255 x 22mm vented discs
S8 is 280x22 compared with 256x22 standard.
LINK
LINK 2
[PHP: 5.8% - SQL: 94.2%]
