Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 b6 tuled ei tööta
Pealkiri: Audi A4 b6 tuled ei tööta (Vastuseid: 3 | Vaatamisi: 1438)
Energi
Registreerunud 13.04.09
postitati 06.12.10 10:12 Tsiteeri
Isend ise 2003 aasta Audi a4 1.6l. Probleem siis selline et ükspäev ei läinud tööle enam ükski tuli ja kojamehed . Mootor käivitub ja salongituled põlevad. Vaatasin ka üle kaitsmed, kuid kõik olid korras.
Tänades ette!
jyrgen61
Registreerunud 19.04.04
Auto: Audi A4 1.6
postitati 06.12.10 12:06 Tsiteeri
Kui kaitsmed korras, siis mina panustaksin massi puudumisele. Samas võib viga olla ka plussis - kontrolli kas kaitsmetele vool peale läheb. Sellest võibolla ka alustaksin.
Audi - Oma ja Hää
samru
Registreerunud 01.02.04
postitati 06.12.10 14:19 Tsiteeri
Algselt postitas: Energi
Tänades ette!
Kõigepealt peaks arvuti järgi panema ja vaatama mida 09-Centr. Electr. räägib. Tulesid ja muid asju kamandab seal aju.
Energi
postitati 06.12.10 19:43 Tsiteeri
Tänud vastajatele:)
Sain vea teada, juhtblokk on maha kärsanud. Kui kellelgi on olemas üleliigne võib teada anda tel 53486980
Teema võib ära kustutada!
[PHP: 30.9% - SQL: 69.1%]
