Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - B4 generaatori remont
Registreerunud 09.04.05
Auto: Audi avant
postitati 06.11.10 20:15
Kas keegi on tegelenud audi b4 l oleva bosch generaatori remontimisega
nimelt kas on üldse asjal mõtet.
vaja oleks
vahetada laagrid (ei logise kuid vabalt pöörlemisel on hääl nagu hõõruks kusagile)
vahetada võlli otsast harjade vaste (ühel sügavam soon sees)
harjad kulunud (olen kunagi juba vahetand)
Kas/kus on ehk võimalik osta renoveeritud gene
sain vist isegi auto korda ;-)
postitati 06.11.10 20:46
Lammutusest saab uue kasutatud. Vaata, et samasugust ei osta kontrolli kontaktrõngad üle enne. Saab ka remontida kuid ei hakka huupi pakkuma mis
maksta võib. Kui meeldib sitast sai teha siis võid kontaktrõngastele vasktraati peale joota ja siis siledaks viilida nii pikanedad ka natuke eluiga.
aaa
Registreerunud 23.02.09
Auto: 80 1.9 d , 80 avant 2.o
postitati 07.11.10 17:17
Vahetasin enda geneka laagrid ja pingeregulaatori. Laagri vahetus oli vastavate tõmmitsatega lihtne. Laagrite kulumisest tingitult hakkas südamik
kesta hõõruma ja iseloomulikku krõbinat tekitama. Laadimine oli muideks sel ajal +20,2 V. Selle tunni või väheke rohkemaga ehk suutis õnneks ainult
bensupumba sisse kõrvetada. Peale laagrite ja regulaatori vahetust töötab genekas laitmatult. Tegemist 35-70A e. 66kw peale pandud genekaga.
A4TQ
Registreerunud 24.07.03
Auto: SQ7, 911
postitati 07.11.10 18:58
Algselt postitas: automees6
Saab ka remontida kuid ei hakka huupi pakkuma mis maksta võib. Kui meeldib sitast sai teha siis võid kontaktrõngastele vasktraati peale joota ja siis
Milleks sellise jamaga tegeleda kui uued kontaktrõngad maksavad olenevalt geneka tootjast 60-120 eek vahele.
Koos laagrite vahetasega maksab töö koos osadega 600-700 eek
[PHP: 47.6% - SQL: 52.4%]
