Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - s4 c4 4,2 väriseb tühikäigul
Pealkiri: s4 c4 4,2 väriseb tühikäigul (Vastuseid: 8 | Vaatamisi: 3588)
waixu
Registreerunud 15.12.07
Auto: RS6 c5 2003
postitati 31.07.10 09:20 Tsiteeri
Tervitused,
Probleem siis selline, et auto väriseb tühikäigul ning käiguga alla 2000 rpm-i puterdab. Samuti on kiirendus kuidagi uimane ja nt. kuuenda käiguga 80-ne pealt kiirendades nõksutab e. siis jätaks nagu midagi vahele. Kui pöörded lähevad üle 2000 rpm-i siis on asi parem aga uimane on ikka.
Kütusekulu on normis, õli ja radika temp. näidukid samuti.
Vahetasin ka paar nädalat tagasi jälle mootori ära ( s6 c4 4,2). Vana mootoriga oli täpselt sama asi, mis oli samuti s6-e oma.
Seega kahtlustan, et asi ei saa olla mootoris, ega vidinates ning andurites, mis mootori küljes on.
Vigasid ei anna ka arvuti.
Kas kellegil on sarnaseid kogemusi.
Andke soovitusi.
arsi
Registreerunud 09.02.06
postitati 31.07.10 09:29 Tsiteeri
Kölab nii nagu taoks 1 kyyynlajuhe kuskilt yle.
waixu
Auto: RS6 c5 2003
postitati 31.07.10 09:38 Tsiteeri
kusjuures küünlajuhtmetega võib mingi jama olla küll, sest eelmise mootori vahetasin just selle pärast ära, et süüteküünla all otsas on mingi väike keraamiline vidin, mis läks pooleks ning kukkus mootorisse.
kas pekkis küünlajuhtmed saavad küünlale mingit kahju tekitada?
arsi
postitati 31.07.10 09:42 Tsiteeri
Midagi head see kindlasti ei tee .
Syytekyynal mootori kylge asetatuna peab töötama .
yanekk
postitati 31.07.10 15:29 Tsiteeri
Ei pruugi sinu mure lahendada aga endal oli midagi sarnast enne mootori remonti.
Kui mootor oli laiali siis sai ka kogu sisselase lahti võetud.
Mitte ühtegi päris korraliku tihendit ei olnud ja kuna õhulugeja on enne neid vigureid, siis minul aitas nende tihendite korda tegemine (mida oli kohe saada, sai ka ikka uued pandud)
http://etka.auto2.ru/epc/cat/au/A6Q/1995/155/49/1721331/
Best ET 12.08 :)
waixu
Auto: RS6 c5 2003
postitati 02.08.10 11:13 Tsiteeri
on kellegil veel ideid. uus juhtmete komplekt maksab 6k :mad:
arsi
postitati 02.08.10 14:22 Tsiteeri
6 kilo on hea pakkumine .
Esmalt võid laenata kuskilt korras juhtmed ja kontrollida, kas vahetus aitab .
waixu
Auto: RS6 c5 2003
postitati 12.08.10 19:18 Tsiteeri
viga leitud. genekas ei lae õigesti. kui kellegil pakkuda, siis oleksin huvitatud.
postitati 13.08.10 10:13 Tsiteeri
Algselt postitas: waixu
Väga huvitav, et generaator sellist anomaaliat vöiks pöhjustada.
Kuidas veale jälile saite, kui diagnostika ühtegi errorit ei tuvastanud - füüsiliselt läbi testri?
[PHP: 16.8% - SQL: 83.2%]
