Pealkiri: Probleem audi a4 (Vastuseid: 6 | Vaatamisi: 1399)
aleksei
Registreerunud 29.06.10
Auto: Audi Allroad 2004/ Audi a4 1996
postitati 29.06.10 07:21 Tsiteeri
Probleem audi a4
Tere,
Kas keegi saab aidata lisades foto või skeemi kust oleks näha, mis nr all elektriliste küljepeeglite kaitse on. Enda autol kaane pealt ei olnud skeemi.
Mõlemad peeglid lakkasid järsku töötamast.
Autoks on audi 14 1996a 1.6 74kw.
jaakk
Registreerunud 23.07.07
Auto: Bmw 525i -2007, sedaan
postitati 29.06.10 07:43 Tsiteeri
Fuse#/Description/Amps
1 Heated washer jets 5
2 Turn signals flasher unit 10
3 Headlight washer, illumination of glove compartment, engine compartment,
climate control, automatic transmission, instrument cluster
5
4 License plate light 5
5 Instrument cluster, seat heating, test connection for cruise control, bulb
monitor for auto-check control, Automatic transmission display, switch
lighting, irror switches and actuators, airbag warning light, outside
temperature indicator, Climate control
10
6 Central locking system 5
7 Anti-lock brake system 10
8 Vacant
9 Mirror heating 10
10 Vacant
11 Cruise control (automatic transmission) 5
12 On board diagnostic system 10
13 Brake lights 10
14 Interior lights, reading lights, anti-theft alarm system, vanity mirror 10
15 Instrument cluster, power windows, climate control, automatic transmission 10
16 Anti-lock brake system, Anti-Slip-Regulation 5
17 Heated door locks 10
18 High beam right 10
19 High beam left 10
20 Low beam right 15
21 Low beam left 15
22 Tail and side marker right 5
23 Tail and side marker left 5
24 Wiper and washer system 25
25 Blower for heating, climate control 30
26 Rear window defogger, mirror heating 30
27 Rear window wiper 15
28 Fuel pump 15
29 Engine timing 20
30 Sun roof 20
31 Tail lights, cruise control, automatic transmission 15
32 Engine timing 20
33 Cigarette lighter 15
34 Engine timing 15
35 Trailer receptacle 30
36 Fog lights 15
37 Radio 20
38 Luggage compartment light, central locking system 15
39 Emergency flasher 15
40 Horn 25
41 Anti-lock brake system 25
42 Vacant
43 Vacant
44 Seat heating 30
Kui nüüd nr 5 kaitse peaks läbi olema, siis peaks sul veel "pime" olema kliima ja välistemp. näidik jms.
aleksei
postitati 29.06.10 10:29 Tsiteeri
Selge- jõuan koju vaatan üle. Kliimat ja välistemperatuuri näidikut antud autol pole ;)
Aga tänud- kui kaitsmega asi ei lahene siis hakkan edasi viga uurima.
aleksei
postitati 01.07.10 07:49 Tsiteeri
Tere,
Kontrollisin üle kaitse on korras ja salongis tuli põleb- peab vist hakkama ukse paneeli lammutama võibolla tegu pistikus või siis juhtmetes?
rainer9968
Registreerunud 02.03.08
Auto: A4 1,9TDI
postitati 02.07.10 03:52 Tsiteeri
Algselt postitas: jaakk
5
10
8 Vacant
9 Mirror heating 10
10 Vacant
13 Brake lights 10
21 Low beam left 15
28 Fuel pump 15
29 Engine timing 20
30 Sun roof 20
32 Engine timing 20
34 Engine timing 15
36 Fog lights 15
37 Radio 20
40 Horn 25
42 Vacant
43 Vacant
44 Seat heating 30
quote]
Millise all asub tagaklaasi kojamehe kaitse.
jaakk
postitati 02.07.10 06:20 Tsiteeri
27 Rear window wiper 15 ehk maakeeli tagumine klaasipuhastaja ja 15A kaitse.
mclx
Registreerunud 04.10.05
Auto: C7 Quattro
postitati 03.07.10 10:29 Tsiteeri
Skeem näitab ka kaitse nr 5. Kontrolli ka nr 9, need seotud omavahel.
[PHP: 18.2% - SQL: 81.8%]
