Pealkiri: A6 2.8 A/T 1998 - kas osta või mitte? (Vastuseid: 16 | Vaatamisi: 2336)
trattiste
Registreerunud 01.06.10
postitati 01.06.10 15:22 Tsiteeri
http://www.auto24.ee/kasutatud/auto.php?id=725528
emmure
Registreerunud 02.06.09
Auto: Audi a6 2.8 v6 quattro
postitati 01.06.10 15:39 Tsiteeri
Ma selline S- ide kohapealt suht loll. Aga mis teeb sellest autost S-line? Tehke mulle ka selgeks.
Project-Massacre
postitati 01.06.10 15:45 Tsiteeri
Algselt postitas: trattiste
Päris lahe küsimus, et kas osta vöi mitte :D
Mina ostaks küll.
S-Line-st ei tasuks siin vast unistadagi.
Emmure:ehk mingi märgike roolil ;)
Wikipedia:
Audi produce a specification of optional sports trim packages to their mainstream models, known as the S line. This is merely a trim specification which allows customers to effect a sporty appearance in their mainstream Audi model. Whilst the specific S line trim parts are designed and produced by quattro GmbH at its Neckarsulm factory, these mainstream cars are still manufactured and assembled by AUDI AG at their relevant factories on the same production lines alongside their other standard models.
Cars with S line trim are not to be confused with the specific high performance offerings - the "S" models (made by AUDI AG), and the "RS" models (made by quattro GmbH); Audi cars with S line trim bear identical performance figures to their counterparts with base or SE trim levels.
trattiste
postitati 01.06.10 16:12 Tsiteeri
Sellest, et S-line ta pole saan ise ka aru...Kuid siis üldiselt, et suht vana masin juba ja kuidas on 2.8 mootoriga...kütte kulu mind ei hirmuta - huvitab vastupidavus? Ja ka sellel masinal siis kere - kui hullult tuleb planeerida roostevõitlusega?
postitati 01.06.10 16:17 Tsiteeri
Kui hulle lakse pole üle elanud ja mingi värvi lennu korral ka kohe jaole asutud, siis muretu isend.
Mootor pidavat köva olema.
98 aasta kohta näeb veel minu arvates vägagi viisakas välja, läbisöit küll vöiks olla kaheldav, kuid autot ei tasuks selle järgi valida.
Köige etem oleks masin oma silmaga üle vaadata, teha piskune proovisöit vöi lasta asises kohas ülevaade teha.
emmure
postitati 01.06.10 16:58 Tsiteeri
Mul sama aasta isend. Ja ütleme nii, et samade lisadega. Mootorit ei tasu karta, kui korralikult vahetada õli, rullikud jne.
Kere minul roostetab poritiiva äärest ja just üks esimene. Ostes oli kiviga sinna matsu saanud ja tsingi maha löönud. Muidu kere peab väga hästi.
Project-Massacre
Leopold661
Registreerunud 17.11.04
postitati 01.06.10 19:22 Tsiteeri
Mina eelistaks manuaali,kuna küttekulu vahe päris suur.
Peres on selline samasugune(ainult pole quattro) ja eriti ökopill ta pole.
Endal oli kunagi sama mootoriga a4 quattro maunaal ja nii oli hea võrrelda neid kulusid.
Aga muidu see mootor :cool:
Mudjamix
Registreerunud 29.03.05
Auto: TT mk2 + Q7
postitati 01.06.10 22:00 Tsiteeri
Naljakas oleks kah kui 2.8 mootorist ootad ökot.Automaat on igati bra selle auto jaoks.Suvel 11L 100km on minu arust suht ok sellise sõidumõnu eest.
Aga osta või mitte seda peab ikka ise otsustama.Kui masin on korras ja kõik kellad viled ka töötavad siis selle raha eest saad ju väga hea auto.Hooldus on muidugi suht kallis.See muidugi oleneb millega võrrelda :P
Ainuke mis mulle konkreetse auto juures ei meeldi, et keegi on mingi kanderaami sinna alla keevitanud :) Käepidemed tagant väljas aga see on juba maitse asi.
Don't drink and drive. You might hit a bump and spill your beer
romka777
Registreerunud 13.08.07
Auto: 2x a6 c4 tdi Q 103 kw & 100 c4 2.6
postitati 02.06.10 09:28 Tsiteeri
Algselt postitas: emmure
Kas selle aasta audisid üldse tsingiti, keegi tark oskas öelda, et mitte.
Simsik
Registreerunud 05.03.08
Auto: B5 V6
postitati 02.06.10 10:08 Tsiteeri
Algselt postitas: romka777
Audi keresid hakati juba ~ 25 aastat tagasi tsinkima;)
Aleksandr
Registreerunud 15.03.05
Auto: Honda
postitati 02.06.10 10:40 Tsiteeri
Algselt postitas: Simsik
Jah, kas mitte isegi aastast 1984 ?
romka777
postitati 02.06.10 15:51 Tsiteeri
Asi selles, et vend kes seda väidab on automaaler ning ta ütles, et on teinud nii mõnegi C5 keretöö kus peaaegu igal isendil on esinenud tiiva flantsides läbivat roostet, seega, milline siis ikkagi tegelikkus on!? Kas tiivad jäetakse tsinkimata?
Liivatraktor
Registreerunud 30.12.08
Auto: Hõbedane
postitati 02.06.10 15:59 Tsiteeri
Ma ka näinud rusikasuurust auku C5 kere poritiivas, samas minu vanal polnud üle auto roostest haisugi. 98a auto siis. Pigem on see nii ,et kui täke-kriim on siis omanikul savi ja laseb edasi minna, kuni tsingikiht maha tuleb ja rooste läheb.
S
lOOOOl
Registreerunud 18.09.08
Auto: Audi, SUV
postitati 02.06.10 17:49 Tsiteeri
Kõige hullemad kohad C5-l on esitiivad ja ukseliistude piirkonnad. Originaalis pole tiibadel isegi kivikaitset.
Aga muidu, kust osad inimesed võtavad, et automaat C5 võtab rohkem kütust, kui manuaal? Kas automaat kast kaalub nii palju rohkem? Tiptronikuga saab täpselt samamoodi käike endale sobival ajal(madalate pööretega) vahetada. Madalate pöörete puhul ei saa mingist libisemisest ka juttu olla. Nii et manuaal pole midagi ökonoomsem.
kiireaudi
Registreerunud 27.09.02
postitati 02.06.10 19:17 Tsiteeri
Algselt postitas: lOOOOl
14,3 vs. 16,0 linn
7,3 vs 7,7 mnt
8,4 vs 9,6 0-100km/h
Tehaseandmed on ju nii lihtsalt leitavad ;)
11,823@191,5km/h
postitati 02.06.10 19:21 Tsiteeri
Ehk asi peitub selles, et kui autoga matsu pannakse, siis asemele pandav osa ei ole tsingitud.
postitati 02.06.10 19:57 Tsiteeri
Räägin küll C4-st, kuid vist väga mööda ei pane.
Automaat kaalub minu autol ikka märgatavalt rohkem kui manuaal.
Vähemalt originaalsoftiga libises just madalamas otsas(alla 2krpm) päris jõhkralt läbi, alles siis kui turbiin lukustub, kaob libisemine ära.
Mis mõtet on osta tiptronicut, kui tahad ise käike vahetada ja sedasi ökotada? Automaat on siiski pigem neile kes ei aja küttekulus absoluutset säästu taga vaid lasevad autol otsustada mis käiguga ta parasjagu sõita tahab.
[PHP: 12.1% - SQL: 87.9%]
