Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Juhtmete värvide tähendused.
Pealkiri: Juhtmete värvide tähendused. (Vastuseid: 1 | Vaatamisi: 2748)
Kotkas
Registreerunud 30.07.03
Auto: paljuklapiline "nuhtlus", S6 4,2 ja Masha 3
postitati 30.05.10 13:55 Tsiteeri
Kuna kaabakad viisid autost järjekordse maki minema, siis üüd tahaks uut makki ühendada, ei ei tea, mis juhe on mis. Kaabaks lõikasid pistiku tagant ära. Oskab keegi öelda, mis juhe kuhu läheb? Autoks on c4 kerega s6 aastast 96.
Eints
Registreerunud 12.03.03
postitati 30.05.10 15:38 Tsiteeri
Punane sinise triibuga +
Pruun -
Valge- antenni remote
Valge sinise triibuga- auto kiiruse signaal
Hall sinise triibuga- taustvalguse signaal
Peenike punane- süütelukust +
Roheline punase triibuga(peenike)- diganost
[PHP: 18.1% - SQL: 81.9%]
