Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Vajaks abi anduri tuvastamisel!
Pealkiri: Vajaks abi anduri tuvastamisel! (Vastuseid: 4 | Vaatamisi: 1011)
-ErNo-
Registreerunud 14.11.09
Auto: audi80b3.91, galant 93 ja Roller.
postitati 26.05.10 20:01 Tsiteeri
Tervit. Asub ta siis a80 1,8 66kw karpamootori tagumise otsa peal. Põhimõtteliselt aku ääre all! Ei ole ühtki lahtist juhet juures ega midagi. Anduril 1 klemm!
http://www.upload.ee/image/600873/Resize_Wizard-1.jpg:)
EX
Registreerunud 03.03.05
Auto: audi 100 1,8 87
postitati 26.05.10 20:35 Tsiteeri
Audi 100-l on selle kohapeal jahutusvedeliku rõhu andur
Kaljoskin
Registreerunud 26.11.07
Auto: Audi 80 2.0 83kW
postitati 26.05.10 20:37 Tsiteeri
Algselt postitas: -ErNo-
Peaks olema õlirõhu tule andur.
postitati 26.05.10 20:39 Tsiteeri
Õlirõhu andur peaks 1,8 seal plokikaane otsas olema. Osadel on sel lihtsalt punn.
-ErNo-
postitati 27.05.10 05:48 Tsiteeri
Algselt postitas: automees6
Okei, siis ei jää muud üle kui sinna juhe kaa taha otsida:D Tänud vastamast!
[PHP: 44.0% - SQL: 56.0%]
