Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A8, Starter
Pealkiri: A8, Starter (Vastuseid: 2 | Vaatamisi: 834)
riho136
Registreerunud 29.09.09
Auto: Audi A8 Quattro
postitati 19.04.10 17:48 Tsiteeri
A8, Starter
Kuidas võimalik maha kruttida A8 starterit, mure selles, et on raskusi käivitamisel, ehk siis, arvatavasti"pendix" tõmbe relee jamab!
APPI!!!
repsu007
Registreerunud 04.08.09
Auto: C7,B6q,B2q
postitati 19.04.10 17:57 Tsiteeri
Vaata enne üle ühenduslüli mis on kõrvalistuja ratta juures kus plus juhe läheb starteri külge ja teine ots läheb kere sisse see võib mädanenud olla.
Raske jalaga.
repsu007
Auto: C7,B6q,B2q
postitati 19.04.10 17:59 Tsiteeri
Ja kui oleks otsinud oleks juba saanud õpetuse.
Raske jalaga.
[PHP: 44.7% - SQL: 55.3%]
