Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Tühikäigu mootor
Pealkiri: Tühikäigu mootor (Vastuseid: 11 | Vaatamisi: 1676)
Lemboss
Registreerunud 05.03.07
Auto: A4 V6
postitati 13.04.10 15:56 Tsiteeri
Tühikäigu mootor
Audi a4 1995 2.6
Küsimus nimelt selline kas on vahet kumba pidi tühikäigu mootor peale panna, kuna käib kahe poldiga ja mõlemat pidi läheb peale?! Kas pistik peab jääma taga- või esiosa poole?
postitati 13.04.10 16:29 Tsiteeri
Kui kinnitused ka teisipidi kohakuti jäävad siis vahet ju pole, et mis pidi on - signaali jooksu see ju ei muuda, iseasi, kuidas on lood pistiku kinnitamise mugavusega.
Lemboss
Auto: A4 V6
postitati 14.04.10 12:17 Tsiteeri
Ega seal vahet jah vist pole kumba pidi. Sain ostetud uue tühikigu mootori aga ega see midagi ei muutnud, ikka pöörded panevad segast, ei teagi nüüd milles viga võib olla? Audihooldus ütles et viga tühikäigu mootoris, kuid vahetus ei muutnunud midagi! Eks reedel forssi saavad äkki seal korda!
postitati 14.04.10 16:46 Tsiteeri
Algselt postitas: Lemboss
Sellisel juhul vöib viga peituda ka äkki vaakumites jne.
Mis möttes pöörded segast panevad?
Lemboss
Auto: A4 V6
postitati 26.04.10 04:27 Tsiteeri
Pöörded kõiguvad ja sõidu ajal kui gaasi lahti lased hakkab kohe mootoriga pidurdama......ja samuti peale pidurdust seisma jäädes paneb paugu esiratastesse kuna pöörded on kõrged ja löög käigukastist!
Viga näitab N71 olevat....andur ise tundub ok......aga viga võib juhtmetes olla....eks lasen elektrikul üle vaadata!
postitati 26.04.10 09:41 Tsiteeri
Aga reaalne ongi ju see, et gaasi vabastamisel hakkab mootor hoogu pidurdama.
Natuke segane selgitus.Kui körged pöörded on?
Oma eelmisel hoidis pöördeid vigase klapi töttu 1100-1200 rpm ja pole küll probleeme olnud, ei pidurdusel ega ka "esiratastele paugu andmisel".
PS: stuff vöiks selle ja N71 teema kokku liita.
linter
Registreerunud 12.11.09
postitati 26.04.10 15:51 Tsiteeri
Kas sa oled proovinud teist aju. Kuna nende mootorite tühikäik on ka seotud vaakumiga mille üks ots läheb mootori sisselaske koldesse ja teine aju otsa.
postitati 26.04.10 16:04 Tsiteeri
Ma olen mitmel 2,6 A4-l kõikuva tühikäigu vag-com abil paika saanud.
Tasub proovida.
OOOO, VW, Seat, Skoda DIAGNOSTIKA, OSTUABI (võimalik üle Eesti), kodeerimine, (de)aktiveerimine, aut. kastide õli, seadistused, DPF-i, õhkvedrustuse mured, läbisõit jne. (Litsentsiga orig. Ross-Tech PRO V2 seade + alati uusim tarkvara ja 19a. kogemust). 2g, HN+, MHI2, MHI2Q uuendused, NAVI 2026-27, VIM, SpeedCam, Carplay, Android Auto aktiv. jne. Läbitud kilomeetreid ei muuda. U2U või 55547002.
jannor
Registreerunud 15.02.09
Auto: 1996 Audi A4 B5 110kW
postitati 26.04.10 20:57 Tsiteeri
Kuna endalgi hiljuti see tühikäigujama üle elatud, aga juhe taha ning probleem lahendatud.
Sul vahepeal aku tühjaks pole saanud? Minul näitkes tuli probleem sellest.
Lemboss
Auto: A4 V6
postitati 27.04.10 21:36 Tsiteeri
Aku sai vahepeal tühjaks küll, kuid peale vea ilmnemist! Eile sai terve päeva elektrikuga asja uuritud, kõik juhtmed üle kontrollitud jne. Midagi ei aidanud.....täna võtsin aju maha ja viisin elektrikule, vaatab üle ehk saab korda!
Arvatavasti viga ongi ajus, kuna muud kõik varjandid üle vaadatud! Aju ise oli kuiv ja niiskuse märkidetta, ning huvitav kuidas saab ta nii tuksi minna et ühe vea ainult tekitab, nimelt siis ei anna signaali tühikäigu mootorile, mistõttu see ringi ei käi ja ei reageeri arvutiga seadistamisele!
Eks jään imet ootama elektriku poolt....... palju kasutatud aju muidu maksma võib? uus oli Forsis 18K :)
raivo33
Registreerunud 15.05.09
postitati 28.04.10 21:00 Tsiteeri
Kui vahetasid tühikäigu mootori siis tuleks teda natuke testriga õpetada .Käisin kunagi enda masinal ka paika panemas .Otsisin ka nagu segane viga algul.
Lemboss
Auto: A4 V6
postitati 28.04.10 21:49 Tsiteeri
Minu ceisi puhul pole testriga midagi õpetada.....proovisin ka seadistada andurit aga mingit tulemust, kuna ju signaal üldse peale ei tule :(
Kellegil muidu 2.6 aju ei vedele üleliia ?:D
[PHP: 47.7% - SQL: 52.3%]
