Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - iseeneslik gaasi andmine,gaasianduri vead? 2,5TD a8 99a
Pealkiri: iseeneslik gaasi andmine,gaasianduri vead? 2,5TD a8 99a (Vastuseid: 5 | Vaatamisi: 2054)
Inferno
postitusõiguseta huviline
Registreerunud 23.09.07
postitati 14.02.10 19:24 Tsiteeri
Selline jama siis,et auto viskab vearesiimi ja ainult jääb käima 1100 rpm juurde kuskil. Peale gaasisensori lahtiühendamist ja uuesti käivitamist (auto jaoks enam viga pole ja korras auto jääb käima tühikäigul) minuoma hakkab aga ise pöördeid tõstma ja mängima nendega, isegi üle 4000rpm - gaasianduri tagasiühendamisel hakkab jälle kõik tööle ja regeerib gaasile(ja saab sõita jälle normaalselt mingi aeg) .
Andurit on testitud esinduses ja seal öeldi,et korras. Täitsa usun seda - viga peab olema mujal . Auto minukäes olnud 2a ja viga tekkis lambist. Algselt lööb põlema abs,esp tuled , vilgutab küünlamärki jne. Üsna probleemne olukord. Ilmselt viskab sinna 1100rpm resiimi peale selle vältimiseks,et maanel ei tekiks ohtlike olukordasid. Teine A8 sama mootoriga on olemas ja saaks juppe vahetada , kui teaks mida vahetada ? Kas diislil mingi TPS sensor ka on ?
Veaks näitab muidu
00777 - Accelerator Position Sensor (G79)
28-10 - Short to B+ - Intermittent
Korra vist näitas TPS viga ka (pole mälus kindel)
jama on ka see,et viga pole koguaeg peal, eile õhtul tuli viga peale 10km läbimisega ala 4x , samas 4 päeva enne seda ei esinenud seda enam.
wookie
Registreerunud 21.02.07
postitati 14.02.10 20:30 Tsiteeri
Algselt postitas: Inferno
Veaks näitab muidu
See meigib ju senssi küll. See võiks olla mingi gaasipedaali asendi sensor, mille kohta aju arvab, et on aeg-ajalt lühises.
Kui andur ise on korras, siis võiks ehk uurida pistikuid ja juhtmeid?
Inferno
postitati 14.02.10 20:55 Tsiteeri
Pistik ja juhtmed üle vaadatud sensori juurest, ei ole seal nagu küll probleemi. Ei oskagi edasi otsida väga kuskilt..
kahjuks teisel audil on vanem sensor , 6 piniga, mul aga 5 piniga. Vahetada samaväärse vastu pole saanud testi mõttes. Aga muidu see sensor ise on väga töökindel,niipalju ,kui uurinud olen .
uurin homme seal kõrvalistuja jalgade juures olevad asjad üle, talv ikkagi ja põrand pidevalt märg.
Küll oleks tore,kui viga oleks lihtne....
10 pin connector pin1=brown/blue to brown/white pin 2 grey/white to green/white pin 3 yellow/green to yellow/green pin 4 grey/red to grey/red pin 5 white/blue to white/blue pin 6 grey/blue to grey/blue. Makes it easier to identify which connector your looking as there are like 5 10 pin connectors at this location.
Inferno
postitati 16.02.10 16:47 Tsiteeri
(auto laupäevast seisnud - võtsin sõitsin garaasi,viga ei olnud)
Võtsin täna sealt kõrvalistujate jalgade juurest lahti ,kakkusin kõik plokid küljest ära ja käisin muud ühendused ka seal kergelt üle. Välja tagurdades tuli viga peale, samas error signaaliks ei olnud enam seekord short , vaid implausible signal mida varem pole näidanud.
Võtsin kaabliga vea maha ja hetkel peale ei ole tulnud nii 15km sõiduga. Eks näis. :mad:
Eints
Registreerunud 12.03.03
postitati 17.02.10 03:57 Tsiteeri
Ühesõnaga mootori aju juures märke niiskuse kahjustustest polnud?
Igaks juhuks võiksid mõõta gaasipedaali andurit mootori ajju juhtmed üle. Kui need korras ja mootori aju pole niiskust saanud, siis gaasipedaali potekas kulunud ja vaja välja vahetada.
Inferno
postitati 19.03.10 07:09 Tsiteeri
Et teema lahenduseta ei jääks siis panen kirja:
Kogu mootori ja kasti ecu peal olev plastkaas oli veetilkasid täis,ecud samuti natuke märjad ja samuti oli ära oksüdeerunud üks pistik, ülejäänud olid silmaga nagu korras. Logistasin neid kõiki sisse - välja ja enam viga pole juba tükk aega esinenenud. Iseenesest see kasti kaas nagu ei peagi olema hermeetiline - tagant on ju kõik lahti nagunii... eest samas 2 polti mul puudus kinnitustest.
Nii,et ilmselt sealt see viga siis tuligi..
[PHP: 43.5% - SQL: 56.5%]
