Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 100 1.9 Ei lae korralikult
Pealkiri: Audi 100 1.9 Ei lae korralikult (Vastuseid: 9 | Vaatamisi: 1137)
pro11
Registreerunud 29.10.08
Auto: Audi A6 C6 3.0tdi quattro, Audi A6 C4 2.5tdi
postitati 09.02.10 07:34 Tsiteeri
Mure siis selline, et auto koha peal käies imeb aku tühjaks. Kui süüte sisse panen ei tule armatuuri aku märki kah, genekas käis remondis. Tuttav ütles, et neil käib laadimine läbi spidoka, vastab see tõele? Äkki on kellegil olnud sama probleem siis saab äkki aidata;)
huljes
Registreerunud 30.01.09
Auto: Audi Cabrio 2.0, Audi A4 2,8Q
postitati 09.02.10 08:25 Tsiteeri
Kui kohapeal ei lae korralikult, kuid sõites laeb, siis panustaks pingeregulaatorit- minekul olevaid harjasid.
Kuid ega ta sul siis ka sõites KORRALIKULT ei lae, loeme seda piisavaks sõidu jätkamiseks.
Mis sul seal genekat remontides vahetati?
Johnny
Registreerunud 23.03.07
Auto: Jeep GC
postitati 09.02.10 08:44 Tsiteeri
Kui armatuuris aku tulukese pirn läbi on siis ei lae tõesti. Ergutus käib läbi pirni ja ise olnud sama probleemiga korra.
Elektri-, remont ja hooldustööd+ custom tehnilised lahendused. LT Service OÜ
huljes
postitati 09.02.10 09:07 Tsiteeri
Kuid jutt oli, et tühikäigul ei lae(seotus pöörete muutumisega)? Pirn toimib kui kaitse ning kui see läbi, siis oleks laadimine täielikult kadunud.
Enda kunagisel skodal oli nii, et üle 5k rpm ei laadinud, sai pingeregulaator koos harjadega vahetatud ja asi korras.
Kuid mis mahutavusega akut kasutad? Ma mõõdaksin laadimis pinge ja aku pinge esmalt ära.
pro11
postitati 09.02.10 09:25 Tsiteeri
Algselt postitas: huljes
Aku on 62Ah ja pinge on kohapeal 12V ja kui gaasi anda läheb 13,8V peale. Paranduses vahetati harjad ja laagrid.
huljes
postitati 09.02.10 09:35 Tsiteeri
Akust ei tohiks probleemi olla, kuid laadimis pinge 12v on madal, 13,8 on hea kui tarbijaid ka taga.
Kas sul harjad koos pinge regulaatoriga või ilma?
pro11
postitati 09.02.10 16:54 Tsiteeri
Ei oska seda õelda kas koos või mitte, kuid harjad tulevad lahti kahe kruviga koos mingi musta kestaga.
Johnny
Auto: Jeep GC
postitati 09.02.10 17:15 Tsiteeri
Kui pirn läbi hakkabki ainult pööretel laadima. Proovi enda auto peal ja võta ergutus juhe lahti. Tühikäigul ei lae ja miski 3000 pöörde peal hakkab laadima. Vähemalt minu autol oli nii.
huljes
postitati 10.02.10 08:53 Tsiteeri
Pirni võib tõesti profulaktika mõttes ära vahetada, kuid see ei ole kindel kas sellest tolku on.
Kui harjad koos nö tabletiga, siis jah koos pingeregulaatoriga(vaata harajade seisukord ka igaks juhuks üle.
Kas ka selline asi on võimalik, et mõne kehva ühenduse tõttu ei anna voolu läbi korralikult?
pro11
postitati 10.02.10 14:05 Tsiteeri
Tänud kõikidele, nädalavahetusel vaatan üle. Ning annan teile teada kui toimima hakkab.
[PHP: 45.3% - SQL: 54.7%]
