Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - kliimaseadme ekraanil kütusekulu näit?
Pealkiri: kliimaseadme ekraanil kütusekulu näit? (Vastuseid: 11 | Vaatamisi: 1844)
nic
postitusõiguseta huviline
Registreerunud 01.05.05
Auto: mõned audid alles
postitati 08.11.09 10:07 Tsiteeri
Kas vastab tõele, et mingi valemiga saab kuvada kütusekulu kliimaseadme ekraanile.
Autoks siis 1994a B4 2,8 V6 ilma "kompuutrita" (küll on see väike auto-check ekraanike)
Otsingu abil ei leidnud sellele vastust...
postitati 08.11.09 10:35 Tsiteeri
Sirvitud igasugu foorumeid, samuti olukorda uurinud ja see ei vasta töele!
Heix
Registreerunud 30.09.07
Auto: VW Phaeton 2011
postitati 08.11.09 10:36 Tsiteeri
Kliima ekraanile saad kuvada vaid kliima tööks vajalike parameetreid.
arsi
Registreerunud 09.02.06
postitati 08.11.09 11:27 Tsiteeri
.....reglina midagi rõõmustavat sealt ei näe ka :)
sass1978
Registreerunud 25.09.09
Auto: A6 C6 2,7TDI
postitati 08.11.09 12:04 Tsiteeri
Algselt postitas: nic
Väikest pardadiagnostikat saad teha küll. Kuvada ekraanile saab igasugust asju, kuid kütusekulu vist mitte.
Uuri linki:
http://wiki.audi-bel.com/wiki/%D0%91%D0%BE%D1%80%D1%82%D0%BE%D0%B2%D0%B0%D1%8F_%D0%B4%D0%B8%D0%B0%D0%B3%D0%BD%D0%BE%D1%81%D1%82%D0%B 8%D0%BA%D0%B0_%D0%BA%D0%BB%D0%B8%D0%BC%D1%8B
tarmo
Registreerunud 05.01.03
postitati 08.11.09 12:33 Tsiteeri
Huvitav, mis reegli punktile sass1978 avatar vastab?
postitati 08.11.09 14:35 Tsiteeri
Algselt postitas: tarmo
OT:
Avatar on konkreetselt ju ära seletatud, mida punkti sa avatari suhtes veel taga ajad?
Arvan, et ei eksi, kuid too avataril olev "punane" ei kuulu jutuks olevale kodanikule.
Krt...kas peaks ka avatari pildi muutmisele röhku pöörama?
tarmo
postitati 08.11.09 14:38 Tsiteeri
OT:
Justnimelt
OttOlesk
Registreerunud 01.10.09
Auto: Tesla
postitati 08.11.09 15:43 Tsiteeri
Kliima pealt olen ainult kiirust paar korda vaadanud, et võrrelda spidomeetri näiduga. Nimelt keegi ütles, et kliima näit pidi kõige täpsem olema.
laur
Registreerunud 14.09.03
Auto: A7 3.0 TFSI
postitati 08.11.09 16:49 Tsiteeri
Ma kah kuulnud seda, et on täpsem. Kui ma õigesti mäletan siis pidi vist ABS anduri pealt kiirust lugema.
Kahju iseenesest et küttekulu ei näe, mul ka kompuutrit pole :P
postitati 08.11.09 17:13 Tsiteeri
Kliimasse tuleb lihtsalt reaalne kiiruseinfo, spidoka viga on aga meelega tootja poolt tekitatud.
Siit teemast leiab infot kliimaploki varjatud funktsioonide kohta. Nagu näha, algas see suht samamoodi. :)
cilaper
Registreerunud 16.06.07
Auto: C5q
postitati 08.11.09 18:25 Tsiteeri
Ei näita see kliima ka õgesti, kui tehase antud mõõdus papud all pole.
[PHP: 41.3% - SQL: 58.7%]
