Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Elektri skeem.A6 (C5)
Pealkiri: Elektri skeem.A6 (C5) (Vastuseid: 5 | Vaatamisi: 2244)
AudiMihkel
Registreerunud 12.12.07
Auto: Mitte audi
postitati 12.10.09 10:36 Tsiteeri
Tere.
Kas kellelgi on Audi A6 1997/98 El. skeeme?
Kas internetis leidub selliseid asju üldse?
Ette tänades: Mihkel.
Loogika & Taktika.
laur
Registreerunud 14.09.03
Auto: A7 3.0 TFSI
postitati 12.10.09 10:43 Tsiteeri
Mille kohta sul vaja on? ElsaWin'is on olemas kõik. Materjali on väga palju. Mina eitea et netis midagi üleval oleks.
carputer
Registreerunud 28.04.08
Auto: Audi A6 Quattro 2.4 V6 121kW
postitati 12.10.09 11:10 Tsiteeri
Autodatast saad ka.
AudiMihkel
Auto: Mitte audi
postitati 12.10.09 17:33 Tsiteeri
Täpsemalt oleks vaja armatuurlaua "vidinate" skeemi, a'la kõik juhtmed ja pistikud.
Võtsin keskkonsooli ära,aga üks pistik jäi üle ja keskmiste õhukanalite rullide valgustus enam ei toimi.
Täna kakkusin kõik jälle maha,kuid ei leia ühtki loogilist kohta kuhu see pistik toppida:)
Selline teemaväline küsimus ka,et kustkohast saaks neid ElsaWin ja Autodata programme? Kuna see Audi jääb minu kätte väga kauaks,siis oleks hea kui midagi sellist on olemas.
Loogika & Taktika.
Memphisc
Registreerunud 21.05.08
postitati 18.10.09 10:40 Tsiteeri
Ei hakka uut teemat tegema. Sooviks teada esimeste istmete all olevate pistikute skeemi ( mis pistik mingi asi on, soojendus, regull, airbag).
Pean silmas siis neid pistikuid:
http://static2.nagi.ee/i/p/520/18/130045836b0182_s.jpg
http://static2.nagi.ee/i/p/520/18/13004579c2d07d_s.jpg
We're drifting slow through the snow on 5th Avenue..
AudiMihkel
Auto: Mitte audi
postitati 20.11.09 18:59 Tsiteeri
Algselt postitas: Memphisc
Mul endal on seal all must,punane ja kollane(lilla). Mu autol el. ainult ülesse ja alla,ning airbag. Niiet ülejäänud on vast kindlalt rikka mehe el. istme regulli omad:)
Loogika & Taktika.
[PHP: 43.7% - SQL: 56.3%]
