Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kuidas kasutada auto salongis kliimaplokki ?
Pealkiri: Kuidas kasutada auto salongis kliimaplokki ? (Vastuseid: 17 | Vaatamisi: 3221)
raemees
Registreerunud 18.09.09
Auto: BMW E90 320dA 2008a
postitati 24.09.09 21:21 Tsiteeri
Kuidagi ei leia otsingust infot, kuidas kliimaplokki autos õigesti kasutada ?
Milliseid nuppe tuleb vajutada ja millal ? nt.kui esiklaas kipub uduseks minema ülevalt poolt,milliseid nuppe hoida all talvel jne. Nuppe on seal ikka üksjagu... Või nt. paigaldada temperatuur 21 peale ja vajutada ülevalt AUTO nupud mõlemad nii vasak kui parem tööle ja edaspidi siis mitte näppida
Audi A4.03a. k
postitati 24.09.09 22:06 Tsiteeri
Pane vastav temperatuur paika nagu meeldib ja vajuta auto. Rohkem pole sel midagi näppida. Kui aken udune hommikul näiteks siis on sel aknale puhumise nupp vajutad seda kui aken puhas vajutad jälle auto peale. Jalad külmetavad vajutad jalgadele puhumise nuppu. Üldiselt pole vaja näppida päris hästi saab se süsteem ise hakkama. ;) A ja talvel on mõnusam kui paar kraadi rohkem panna 23-24 näiteks. Vent hakkab puhuma vastavalt mootori temperatuurile seega seda pole vaja ka ise näppida(talvel ma mõtlen).
raemees
postitati 25.09.09 19:25 Tsiteeri
Ventilaatori kiirust millist keegi kasutab ?
postitati 25.09.09 19:37 Tsiteeri
Pane meeldiv temperatuur paika ja vajuta AUTO. Ega se mingi tuumateadus pole. ;):P Selleks see kliimaautomaat mõeldud ongi, et ise midagi näppima ei peaks. Sul muidu selline? http://p3.focus.de/img/gen/G/A/HBGAA0jOC4R_Pxgen_r_311xA.jpg
postitati 25.09.09 19:48 Tsiteeri
Näiteks minul on kliima 96. aasta masinal sätitud jalgadele, esiklaasile ja küljeklaasidele ning auto nuppu ma pole veel näppinud.
Hetkel kraadid sätitud 22-le ja vastavalt mootori temp.töusule hakkab ka puhur selle järgi kiirust lisama ja seda seniks, kuni salong vastava temp.juures, peale temperatuuri saavutust ventilaatori kiirus langeb.
Päeval, kui päike on näiteks auto juba soojaks mingil määral kütnud siis kliima automaatselt kiirust ei tösta, displeil ainult esimene kriips ja örnalt on tunda, et midagi nagu kusagilt puhuks.
Lisan veel juurde, et ei kasuta sellist varjanti hetkel, kus kliima rakendaks ka tööle külmaine ringluse, st. displeil puudub helbekese tähis.
Kui vajutaksin näiteks mingil hetkel auto funktsioonile vöi ainult esiklaasile, siis rakendub ka külmaine ringlus ja displeile ilmub ka helbekese tähis.
Kordan veel, et antud jutt oli 1996 aasta masina kohta.
postitati 25.09.09 20:00 Tsiteeri
Suht sama tulemuse annab, kui vajutada Auto nuppu ning seejärel helbekese nuppu. Kliima kompressor lülitub välja, ning edasist sooja edastamist jääb jagama kliimaplokk nii kuis heaks arvab. Vähemalt sellist variant ikasutan enda masinal. Täna õhtupoolikul sõites sai proovitud, et kui tempaeratuuriks on valitud 22c, siis soojendus auto seades jagab igalepoole nii kuis vaja, et temperatuur ühtlasena hoida. Vahepeal puhus aknale mõnuga sooja, ja vahepeal jalgadele. Mitte koguaeg, aga piisavalt et sama temperatuur igalpool olemas oleks.
postitati 25.09.09 20:03 Tsiteeri
Konditsoneeri saab ju ka auto korral helbe nupust välja lülitada. Uuemal on selleks econ nupp. Eks igaüks kasuta muidugi omamoodi. ;)
postitati 25.09.09 20:07 Tsiteeri
Jah, selles on sul öigus, et sama tulemus, kuid minu kirjutuse pöhjal tuleb öhuvoolud konkreetsetest kohtadest.
postitati 25.09.09 20:19 Tsiteeri
Mul tuleb täpselt samadesst kohtadest kui sul, kuid kui sinu variandi puhul puhub alati igast võimalikust kohast välja, siis automaatika peal kasutab kliimablokk selleks paigaldatud andureid, et otsustada kuhu on vaja puhuda rohkem ja kuhu vähem. Kasutab ju kliima kõiki neist kolmest võimalikust suunast, kuid kui jalgeade juures on vaid 19c samalajal kui laes on 23c, siis puhub ta veidi rohkem jalagedele kui mujale, et saada võimalikult kiirelt ühtlane temperatuur.
raemees
postitati 26.09.09 07:44 Tsiteeri
Algselt postitas: automees6
Jah on see
rainer9968
Registreerunud 02.03.08
Auto: A4 1,9TDI
postitati 26.09.09 08:53 Tsiteeri
Kui esiklaas on udune siis vajuta kliima all vasakus nurgas olevat nö. aknamärki, mis asub istmesoojenduse reguleerija kõrval, siis puhub täisvõimsusel esiklaasile sõltumata mootori- ja salongi temperatuurist, muidugi peaks võtma vist kondi ka järele aga selle saab välja lülitada.
maikl369
Registreerunud 13.08.08
postitati 26.09.09 09:15 Tsiteeri
Minul A6 1997.aasta masinal kah paras jama sellega...Ei oska mina seda veel kasutada...Panin temperatuuri näiteks 23c ja panen AUTO nuppu läheb kliima pump kah tööle...
postitati 26.09.09 09:22 Tsiteeri
Algselt postitas: maikl369
Selliselt vist toimivad enamjaolt köik Audi kliimad, kuid alati on vöimalus kliima pumba töö katkestada nagu eelpool ka mainitult, vajutades helbekese vms. vastava tähistusega nuppu ning süsteem toimetab automaatselt vastava temperatuuriga edasi - vahe lihtsalt selles, et töösse ei rakendata külmainet.
jõuvanker
Registreerunud 21.03.03
postitati 26.09.09 09:25 Tsiteeri
Algselt postitas: raemees
Audi A4.03a. k
Kõige lihtsam, loe automanuali e. kasutusjuhendit! See ei ole ometi ju keeruline, või siisiki?
exess
Registreerunud 28.05.06
postitati 26.09.09 09:41 Tsiteeri
Algselt postitas: jõuvanker
Ja kui manuali käepärast pole,siis foorumist küsida ei tohi jah?:o
Pisike punane putukas
jõuvanker
postitati 26.09.09 13:18 Tsiteeri
Algselt postitas: exess
Nagu näha, tuleb igasugu "lambi" vastuseid, mis ei puutu kokku üldse B6 kere kliimaga. Seega, on parim variant võtta manual ja lugeda. Elemntaarne. Kui manualist aru ei saa, alles seejärel võiks uurima hakata teiste kodanike käest.
postitati 26.09.09 13:24 Tsiteeri
Jöuvanker: kas tahad öelda, et näiteks b5 ja b6 kliimad on erinevate töövötetega?
Suhtkoht kahtlen.
Tööpöhimöte jääb siiski ju samaks, kuid erinevused tulevad vast juurde juba siis, kui tegu 2 vöi enam tsooni kliimaga
Big
Registreerunud 26.11.03
Auto: Audi, Ford, Vaz
postitati 26.09.09 15:45 Tsiteeri
B6`l ongi kahetsooniline kliima.
Ega jah, enamus siin juba lahti seletatud.
Kasutan ka alati AUTO reziimi, econ`i hoian väljas, kui just jube palavus pole.
Muid nuppe kasutan vaid juhul, kui näiteks jalad märjad või esiklaas väga udune. Vastavalt siis tuleb erinevaid manuaalseid funktsioone kasutada.
[PHP: 25.2% - SQL: 74.8%]
