Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleem immoga
Pealkiri: Probleem immoga (Vastuseid: 7 | Vaatamisi: 1102)
rkrimm
Registreerunud 09.06.08
Auto: V8 4.2TT man projekt; S6 2,2t man.
postitati 23.09.09 16:01 Tsiteeri
Probleem immoga
Tere.
Mure siis selline ja suurim hetkel - autoks on audi v8 algselt 3.6 automaat millele on peale istutatud audi s6 4.2 manuaal (AEC). Ning mure siis selline, et süütelukus võtit keerates ei võta starterit ega bensiinipumpa taha. Diagnostika ütles sellise probleemi nagu "engine start blocked by immobilizer".
Sai siis võetud tee ette elektriku juurde aju näpus, kuna targemad mehed rääkisid et see tegelane on ennegi aju näppinud nii, et immo ära kaoks, kuid sama targalt tulin ka tagasi, kuna tema arvates on mitte käivitumine kuidagi seotud käigukasti ajuga. See aju ka tagasi külge siis kuid üllatus kui suur, et ikka ei midagi.
Nüüd siis palve teie kui targemate poole, et milles on kala ? Mis põhjustab seda, et starter ja bensupump ei saa toidet ?Kas on reaalselt kuskil ning kus peidus immo blokk kui selline mis niiviisi näkki keerab ? Kui on siis kus ning mida ette võtta sellega ? Või on soovitada elektrikku kes on pädev seda lahendama ?
Tahaks oma v8 juba liikuma saada :(
Tänan tähelepanu eest.
samru
Registreerunud 01.02.04
postitati 23.09.09 17:45 Tsiteeri
Tehase immo ei plokeeri starterit ega bensupumpa. Igal juhul peaks auto vähemalt 1-2 sek. käivituma.
Kui sa panid sinna manuaalkasti siis loomulikult ei lase ta starterit anda, sest starteri releele ei tule käigukangi asendi infot P ja N.
rkrimm
postitati 23.09.09 17:59 Tsiteeri
Tänud vastuse eest.
Järgmine küsimus siis, et kuiskohast see signaal tuleb - kastist või kuskilt käiguvalitsa juures, ning kuidagi seda ümber mängida :)
samru
postitati 23.09.09 19:40 Tsiteeri
Algselt postitas: rkrimm
Tänud vastuse eest.
Info peaks tulema aut. kasti küljes olevalt multifunkts. lülitist roheline juhe ning sinna "maa" (pruun valgega) peale lasta. See juhe läheb läbi ka keskluku ajust kui on olemas tehase alarm.
Eints
Registreerunud 12.03.03
postitati 24.09.09 03:08 Tsiteeri
V8 on tehase signaga seotud ka starteri ahela katkestus;)
Oled kindel, et kõik juhtmed auto ja uue mootori aju vahel on õigesti ühendatud? Kui ajust bena pumba releele signaali ei tule, siis ei lülita viimane pumpa järgi.
samru
postitati 24.09.09 06:07 Tsiteeri
Algselt postitas: Eints
Jah, ma ju kirjutasingi, et see sama roheline juhe läheb läbi keskluku pumba kui on tehase alarm peal.
rkrimm
postitati 24.09.09 07:23 Tsiteeri
Suured tänud info eest, lähipäevil proovin järgi selle ning loodan parimat :)
rkrimm
postitati 24.09.09 13:47 Tsiteeri
Suured tänud kasutajale samru kelle õpetuse järgi sain starteri tööle :)
[PHP: 38.3% - SQL: 61.7%]
