Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - mõningad probleemid
Pealkiri: mõningad probleemid (Vastuseid: 0 | Vaatamisi: 836)
allan311
postitusõiguseta huviline
Registreerunud 08.08.07
Auto: audi 100 2,6 V6
postitati 21.09.09 18:03 Tsiteeri
mõningad probleemid
Avastasin enda Audi (100 2,6 v6 110 kw.) armatuuri alt kaks lahtist pistikut: Esimene neist on neljakandiline 9 auguga millest on kasutuses neli auku, nr.8 - kaks pnast koos, nr.6 valge, nr.2 pruun/must ja nr.4 -kaks kalli koos. Ja teine on pikklik nelja auguga neist kasutus on kaks, nr.1- must/valge ja nr.2 - must/pruun nr.3 ja 4 on vabad.
Siis on veel läbi lõigatud kaks juhet, mis on samas pundis, mis tuleb kompuutri hoovast. Ja on ka läbi lõigatud üks peenike pruun juhe.
Ja kõige suuremat muret teeb mulle see, et kui annad pööret, siis hakkab kompuutris vilkuma tikuv õlikannu kujutis.
[PHP: 44.3% - SQL: 55.7%]
