Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi a4 96 1.8t avant kütusesensor(paagis)
Pealkiri: Audi a4 96 1.8t avant kütusesensor(paagis) (Vastuseid: 3 | Vaatamisi: 1045)
Khubic
Registreerunud 17.07.09
Auto: a4 1.8t
postitati 10.08.09 09:45 Tsiteeri
Kütusesensoriga selline jama, et on vist väga palju, väikesekoguse bensiiniga sõidetud, kuna alumine osa sensoril ei tööta, väljavõttes oli näha, et läbikulunud või noh, suuresti ära hõõrdunud.
Kas on ka mingeid alternatiive sellele, sest no vähemalt enda jaoks tundub 1000 krooni sellise väikese plaadi eest ikka väga palju küsitud. Või siis ei suutnud ma ennast poes piisavalt hästi väljendada ja pakuti lihtsalt valet asja?
jaakk
Registreerunud 23.07.07
Auto: Bmw 525i -2007, sedaan
postitati 10.08.09 11:48 Tsiteeri
Kahjuks muud töötavat alternatiivi pole, kui osta kas kasutatud andur või siis ikkagi poest see 1500 kr maksev täiskomplekt.
DiaLAB
Registreerunud 04.11.06
Auto: Audi A6 Avant
postitati 11.08.09 05:16 Tsiteeri
Arvatavasti Multitronicu aju, diagnostika ilmselt kinnitab seda.
See on remonditav.
http://www.dialab.ee - Chiptuning, DPF off, Adblue off, EGR off, DTC off, etc.
jaakk
postitati 11.08.09 06:05 Tsiteeri
Algselt postitas: DiaLAB
See on remonditav.
Bensiinipaagi tasemeandur on seotud multitronicu ajuga?? Vähe rappa pannud teemaga vist :)
[PHP: 44.2% - SQL: 55.8%]
