Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Käivitamisega probleeme ???
Pealkiri: Käivitamisega probleeme ??? (Vastuseid: 3 | Vaatamisi: 983)
ejey
Registreerunud 07.06.09
postitati 07.08.09 15:02 Tsiteeri
Tere
autoks audi 100 c4 2.0 92a.
Mure siis selles et aeg ajalt auto starter ei hakka taha...
keerad ca 4 korda võtit aga ei midagi
ja siis viiendal korral hakkab nagu poleks midagi olnudki
ja samas trikitab ka sõiduajal... suvalisel hetkel sureb välja
milles võib asi olla ???
postitati 07.08.09 15:20 Tsiteeri
Algselt postitas: ejey
Tere
Ehk tegu vigase süüteluku pöhjaga.
Vöta ette korra =otsing= ja tipigi sinna =süüteluku pöhi= ja ehk saad targemaks.
ejey
postitati 07.08.09 15:41 Tsiteeri
tänud
postitati 07.08.09 15:49 Tsiteeri
Minu antud sisuga soovitus ei toimi - vabandust.
Kiika siit!
[PHP: 49.7% - SQL: 50.3%]
