Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kliima/Automaatkäigukastiga probleem
Pealkiri: Kliima/Automaatkäigukastiga probleem (Vastuseid: 1 | Vaatamisi: 1041)
KohalikRambo
Registreerunud 05.08.09
postitati 05.08.09 17:34 Tsiteeri
Tervist !
Nimelt endal 93.a. Audi 100 ja probleem siuke : kliima displeid näitavad osaliselt, et ei näita palju kraade autos on jne. Ja kliima ise puhub ka ühte soojust , tahad külemaks ei lähe.
Siis automaatkäigukastil on siuke probleem , et võtab ainult ühe käigu sisse. Ei vaheta käike , sõidad 100-ga on pöörded 5000 peal ja seal armatuurlaual asuv käigunäitaja ( näitab mis käik on sees) , näitab et oleks nagu kõik käigud sees. :o
Isiklikult arvan, et viga elektroonikas. Auto seisis mingi aasta ja peale seda jamab. :)
Oskab keegi aidata ?
Eints
Registreerunud 12.03.03
postitati 06.08.09 03:04 Tsiteeri
Ei väsi kordamast et mõlema vea puhul alustuseks diagnost abiks. Kliima puhul võib viga olla plokis või ploki külm joodetes. Õhuklappide juht mootorites. Automaat kast on sul millegipärast avarii reziimis ja selle põhjust enne diagnosti teada ei saa;)
[PHP: 47.3% - SQL: 52.7%]
