Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 98.a 2.5 TDI nukkvõllide kontroll - palju maksab?
Pealkiri: 98.a 2.5 TDI nukkvõllide kontroll - palju maksab? (Vastuseid: 8 | Vaatamisi: 2668)
juunior01
Registreerunud 17.11.08
postitati 05.07.09 14:56 Tsiteeri
Kus sellist teenust pakutakse ja palju see umbes maksma läheb? Tean, et audihooldus.ee on ka olemas see, aga teenuse hinda pole.
epic
Registreerunud 26.05.05
postitati 05.07.09 15:20 Tsiteeri
No kisu kõrvalistujapoolne klapikaas maha ja vaata, mis seal all on. Milleks selle eest kellelegi raha maksta ?
tnx
Registreerunud 03.10.05
Auto: Audi A8 Quattro
postitati 05.07.09 17:47 Tsiteeri
Algselt postitas: epic_metal
Kas on siis vahet ka nendel pooltel,kuluvad erinevalt,tavaliselt juhipool vahetatud?
epic
postitati 05.07.09 22:16 Tsiteeri
Ei, lihtsalt kõrvalistujapoolset kaant on kergem maha võtta - vähem asju ees.
Eints
Registreerunud 12.03.03
postitati 06.07.09 05:05 Tsiteeri
Või siis õlikork maha ja piilu taskulambiga sisse kas on nukal randid peal või mitte;)
epic
postitati 06.07.09 07:34 Tsiteeri
Jah, sealt on ühte nukka näha küll. Kuigi tegelikult hea oleks mõlemad kaaned maha võtta. Nad kipuvad ju nookureid laiali viskama (seda muidugi juba siis kui nukad / nookurid tõesti kulunud on).
erki.t
Registreerunud 06.07.06
Auto: Got burger? (Jeep)
postitati 06.07.09 08:19 Tsiteeri
http://foorum.audiclub.ee/viewthread.php?tid=46848&page=1&highlight=#pid281505
Ülaltoodud teemas Juks11 pakub teenust kõnealust teemat - postitamise ajal on hind olnud vahemikus mõnisada-2000.-kr sõltuvalt kontrolli käigus kuluvatest lisamaterjalidest (tihendid jms)
Võta otse ühendust audihooldus.ee inimestega, saad kindlasti mingi objektiivse ja pädeva hinnapakkumise - milleks siin niisama lihvida?
Kirjuta teiste harimiseks siis teema lõppu ka:
kus tegid;
mis maksis;
oma rahulolu tulemusega.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 06.07.09 19:15 Tsiteeri
Kogemuste põhjal julgeks öelda,et reeglina on kaardilugeja poolsed nukad hullemas seisus.
epic
postitati 06.07.09 19:47 Tsiteeri
Ja seda võibolla sellepärast, et juhipoolsed on juba vahetatud. :)
Igatahes ühel autol, mida minul au oli korda teha, oli visanud juhipoolsed nookurid laiali ja ikka nii õnnelikult, et nende tükid nukkvõlli ja plokikaane vahelt läbi käisid. Seega vahetasin nuka, kaane, tihendid, nookurid ja seibid.
[PHP: 9.8% - SQL: 90.2%]
