Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - a4 kliima
Pealkiri: a4 kliima (Vastuseid: 6 | Vaatamisi: 2546)
Eints
Registreerunud 12.03.03
postitati 06.07.09 04:50 Tsiteeri
Alustuseks arvuti järgi ja kliima vead ning pumba väljalülitus põhjused ülevaadata.
kenno173
postitusõiguseta huviline
Registreerunud 14.07.08
postitati 06.07.09 15:26 Tsiteeri
Algselt postitas: oldsix1234
mure siis järgmine ostsin just 97a a4 avant 1.8t 110kw quattro ja kliima ei tööta, kui seda lumehelbe pildiga nuppu vajuta lööb küll selle pildi polema aga külma ei tule, vaatasin ka mootori juurest ja see kliima rihm mis kliima pumba peal jookseb on ok jookseb ja puha aga ei vota nagu pumpa järgi sõber seletas et kuidagi elektrooniliselt peax seda tegama kui järgi lülitad kliima aga seda ei juhtu. palun aidake ei tea audidest midagi nii et vabandust kui kuidagi mööda või valesti asjale lähenesin.. ette tänades üx murelik quattro omanik:(:(:(
pumba sidur võib olla kinni ja sellepärast ta ei lähe tööle.
proovi võta vasakul pool kapoti alla sealt kus kliima torud salongi jooksevad on üks andur. Sealt pistik lahti ja väike traadi jupp ja ühendadpistiku juhtmed omavahel kokku ja kui tööle hakkab on asi selles anduris ja kui ei hakka siis võib asi kas kaitsmes või mõnes muus elektri kalas olla või üldse pumba sidur katki.
wahtra
Registreerunud 24.09.08
Auto: Audi A6 Avant 2.5 TDI 110kw 2000.a
postitati 06.07.09 15:40 Tsiteeri
Mul oli pumba sidur kinni, sellepärast ei töötanud.
zaks
Registreerunud 20.03.06
Auto: c7.5 Bitdi
postitati 06.07.09 18:21 Tsiteeri
tavaliselt vajab ikka täitmist.
Raika
Registreerunud 03.11.03
postitati 07.07.09 04:46 Tsiteeri
Kui "lumehelvest" vajutad, kas siis mootori pöörded muutuvd/kõiguvad? Kui jah siis võtab pumba järgi. Kui ei siis peaks sellest teemast abi otsima. Kui võtab järgi siis suure tõenäosusega süsteem R134a gaasist tühi. Täitmiseks erinevad kohad olemas, aga koha valikul uuri kindlasti järgi, et seda tehtaks spetsiaalse aparaadiga. Aparaadiga siis kontrollitakse enne süsteemi lekkekindlust kui see ok, lastakse gaas sisse koos õliga.
oldsix1234
Bännitud
Registreerunud 01.07.09
Auto: audi a4 avant quattro
postitati 11.07.09 15:15 Tsiteeri
mure siis järgmine ostsin just 97a a4 avant 1.8t 110kw quattro ja kliima ei tööta, kui seda lumehelbe pildiga nuppu vajuta lööb küll selle pildi polema aga külma ei tule, vaatasin ka mootori juurest ja see kliima rihm mis kliima pumba peal jookseb on ok jookseb ja puha aga ei vota nagu pumpa järgi sõber seletas et kuidagi elektrooniliselt peax seda tegama kui järgi lülitad kliima aga seda ei juhtu. palun aidake ei tea audidest midagi nii et vabandust kui kuidagi mööda või valesti asjale lähenesin.. ette tänades üx murelik quattro omanik:(:(:( nii nyyd selgus et voolu pole juhtmes mis läheb kliima pumpa, ja kaitsmed tunduvad koik ok kas kliimal voib kusagil eraldi kaitse olla....
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 11.07.09 16:57 Tsiteeri
Kui süsteemis ei ole piisavalt külmaainet,ei teki ka sinna kompressori otsale voolu.
Mine lase oma süsteem ära täita ja kliimast veakoodid lugeda.
Või vastupidises järjekorras.
[PHP: 12.4% - SQL: 87.6%]
