Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Eelsüüteküünalde tuli?
Pealkiri: Eelsüüteküünalde tuli? (Vastuseid: 9 | Vaatamisi: 2671)
Mestizo
Registreerunud 06.04.08
Auto: B6 1,9 tdi 96kw 2002
postitati 19.05.09 14:35 Tsiteeri
Küsimus siis selline ,et millest hakkab vahest peale käivitust ca 2 min eelsüüte tuli vilkuma ja kui suretan välja ja panen uuesti käima siis enam ei vilgu?
jyrisoo
Registreerunud 06.10.07
Auto: Audi Cabrio 1,9TDI
postitati 23.05.09 21:52 Tsiteeri
see tuli hakkab tavaliselt siis vilkuma kui mingi probleem mootoris/toitesüsteemis. Diagnost vast lahendus
taivo
Registreerunud 31.07.05
Auto: AUDI A6 2,5 TDI (C4) QUATTRO
postitati 30.05.09 08:22 Tsiteeri
Minu omal hakkab ka aeg ajalt vilkuma, kui vajutada korra pidurit siis kustub ära. Oskab keegi sellele seost leida?
jokerAudi
Registreerunud 09.02.08
Auto: Superb 2018
postitati 30.05.09 09:12 Tsiteeri
Algselt postitas: taivo
Jap. Vaata piduritulede pirnid üle. Minu Audil oli sama kala. Sõidu ajal hakkas eelsüüteküünla tuld vilgutama, korra puudutad pidurit, kaob ära ja mingi 20 min pärast hakkab uuesti. Mõlemad piduritule pirnid olid läbi põlenud :P Vahetasin ära ja siiani pole enam vilkunud :D
Väga imelik, kui piduritulede läbipõlemisest hakkab vilkuma eelsüüteküünalde tuli :o
taivo
postitati 30.05.09 14:54 Tsiteeri
Pirnid töötavad, mul muidu LED-id sees. Aga vilkus ka siis, kui veel tava pirnid sees olid.
Vilkumisega on ka nii, et mõnikord ei hakka üldse vilkuma ja teinekord laseb iga mõne minuti tagant. Ära tüütab see piduri tallamine:mad:
jokerAudi
Auto: Superb 2018
postitati 30.05.09 15:01 Tsiteeri
Hmm..no siis oleks vast tõesti targem lasta juhe sappa pista ja diagnostika lasta teha autole :)
taivo
postitati 30.05.09 15:31 Tsiteeri
Antud olukorras diagnost vast jah, parim mõte;)
Marx0
Registreerunud 25.10.07
Auto: S4 B6
postitati 31.05.09 16:30 Tsiteeri
Pead küll ei anna aga minuteada on eelsüüte tuluke seotud veateadetega (seda muidugi vanematel mudelitel). On erinevaid viise kuidas märku annab, süüte sissekeeramisel külmast peast ei lähe eelsüüte tuluke põlema ja tuluke läheb põlema või hakkab vilkuma töötava mootoriga.
Rain
Registreerunud 05.10.03
Auto: Allroad ja A6 Allroad
postitati 31.05.09 16:53 Tsiteeri
Piduritulede lüliti teeb ka seda pulli. Mul sama jama oli. Audil suht tüüpiline viga. Foorumis juba eelnevat ka sellest juttu olnud. Otsing teeb imet.
Ahjaa võiks selle ka ära mainida mis auto, mis aasta ja mis mootor.
taivo
postitati 31.05.09 17:36 Tsiteeri
Audi A6 2,5 TDI 85 kw (AAT).
Mida see lüliti siis teeb (ei tee), pidurituled töötavad ilusti. Minu omal muide lüliteid kaks tükki, teine vast püsikiirusehoidja valmidus. See teine lüliti mul hiljuti lollitas (halvasti reguleeritud) ja tõmbas vahest hingest kinni. Aju arvas, et keegi tallub pidureid ja tõmbas kütuse maha. Peale reguleeringut viga kadus (järelikult lülitid korras) aga tuld vilgutab vahest ikka.
[PHP: 10.5% - SQL: 89.5%]
