Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mootoril tõmme kaob peale 4000 rpm'i 1.9tdi
Pealkiri: Mootoril tõmme kaob peale 4000 rpm'i 1.9tdi (Vastuseid: 6 | Vaatamisi: 2147)
kaido21
Registreerunud 02.12.05
Auto: audi a6
postitati 17.03.09 21:08 Tsiteeri
4000 pöördeni kiirendan ära ja pärast seda auto uimane. Süüde välja,uuesti käima siis jäle norm. (audi a6 1,9tdi 99a)
Auto: 6x4x4
postitati 17.03.09 22:13 Tsiteeri
Alustame siis puhtalt lehelt.
Kui süüte välja ja sisse keeramise peale asi taastub, siis mingid andurid panevad kala. Diagnost abiks, muu siin ei aita.
westa
Registreerunud 26.06.03
Auto: Audi A6 Avant C4 2,5TDi,Audi A4 Avant 2,6 V6,Audi 100 C4 2,5TDi,Audi 5000 2,0d,Audi 80 B3 1,8
postitati 17.03.09 23:20 Tsiteeri
Kas kütusefilter on värskelt vahetatud?
Kas külma ja sooja mootoriga samad sümptomid?
kaido21
Auto: audi a6
postitati 18.03.09 06:48 Tsiteeri
Kütusefilter kuu tagasi vahetatud.Külma mootoriga pole proovinud.
kylaline90
Registreerunud 11.09.06
Auto: C4
postitati 18.03.09 07:51 Tsiteeri
huvitav, kui kaugele peaks seda tõmmet siis ka jaguma diislil? 6000-ni? rõhuklapp avaneb 4000 peal ning loomulik ju, et tõmme kaob... või olen ma millestki valesti aru saanud?
veekaheksa
Registreerunud 07.09.03
Auto: A4 TDI quattro, S8 40V
postitati 18.03.09 09:06 Tsiteeri
Kas kunagi oli tõmme peale 4000 rpmi sul sellel autol?
Lisan siis statistika mõttes siia väiksed numbrikesed:
81kW@4150rpm - 235Nm@1900rpm
191kmh / 12.7s 0>100kmh
Kustutasin siit eelneva jura ära. Juhul kui mootor fuel cuti teeb, siis on ju ikka mingisugune jama olemas. Kas läheb mõni väärtus üle lubatu ja poobki kütuse etteande kinni(fuel cut ja avariireshiim). Ikka ja jälle diagnostimees suudab sind aidata.
NB! Ja diagnostimehe juurde minnes tasub see 'viga' tekitada ja siis mootor tööle jätta. On võibolla kohe midagi näha kui juhe külge läheb.
Samzik
Registreerunud 12.09.04
Auto: Passat 1.9/96kw 4WD 2004, audi 90 2.1/134kw q 87A
postitati 18.03.09 10:04 Tsiteeri
Pigem peetakse silmas ilmselt seda, et peale 4000rp käimist läheb auto avarii rezimi. Mis tavaliselt tähendab seda: 1. kas on mõni vaakum voolik väsinud ja tõmbab vaakumiga kokku 2. poob turbo geomeetria hoova vaakumi membraan näiteks. Ja kohe kui tekib rõhuga anomaalia lülitab aju avarii reziimi mis peale vea kadumist ja süüte sisse välja keeramist nullitakse. Arvutiga vaadates on tavaliselt viga näha.
Pakkuda uus Haldex õlipumba elektrimootor. E parandan mittetöötava mootori+uued tihendid. Mbl: 55 55 88 55.
[PHP: 16.4% - SQL: 83.6%]
