Erkiito
Registreerunud 19.03.06
Auto: Audi A6 Avant 2,4V6
postitati 10.03.09 14:11
A6 VAG probleem
Tegin siis oma värskele A6-le diagnosti ja viskas ette allolevad koodid. Ilmselt on ABS/ASR aju peetis omadega. Oskab keegi öelda milline lambda see
peetis on? Ja kuidas neid teisi koode peaks defineerima?
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 552 F
Component: 2.4L V6/5V MOTR AT D03
Coding: 05152
Shop #: WSC 02325
1 Fault Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4B0 927 156 BB
Component: AG5 01V 2.4l5V RdW D14
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 C
Component: ABS/ASR 5.3 FRONT D10
Coding: 00000
Shop #: WSC 65535
1 Fault Found:
00623 - ABS/Transmission Electrical Connection
35-00 - -
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 Q
Component: öAA6-Klimavoll
Coding: autom
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 919 881 AX
Component: C5-KOMBIINSTR. VDO D19
Coding: 05062
Shop #: WSC 44920
IMMO-IDENTNR: AUZ7Z0E2732302
No fault code found.
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 D
Component: Zentralverriegelung D32
Coding: 04673
Shop #: WSC 02325
1 Fault Found:
01559 - Drivers Door
60-00 - Won't Safe
madu
Registreerunud 31.07.07
Auto: A8 D4
postitati 10.03.09 14:16
parem enne katte olev lambda pekkis
Erkiito
postitati 10.03.09 14:34
veel mingeid tähelepanekuid?
Erkiito
postitati 10.03.09 17:38
Krt ma ei saa enam üldse aru sellest kas see kuradi ABS/ASR aju on seotud ka püsikiirusehoidjaga, sest mul hetkel ASR aju näitab viga ja püsikas ei
tööta kas võimalik et see püsikas ei tööta selle sama aju pärast või on mul see kuradi suunatule kang hoopis peetis????
samru
Registreerunud 01.02.04
postitati 10.03.09 17:53
| Tsitaat: | Algselt postitas: Erkiito
tööta kas võimalik et see püsikas ei tööta selle sama aju pärast või on mul see kuradi suunatule kang hoopis peetis???? |
ABS - i ajurike võib igasuguseid jamasid põhjustada. Targem oleks aju korda teha ja siis muid vigasid remontima hakata.
PS! Aju on remonditav.
Erkiito
postitati 11.03.09 10:37
Kas muidu püsikiirusehoidja sisse lülitamisel peaks mingi tuluke süttima ka armatuuris??? või on 99 aasta a6-l teistmoodi?
Erkiito
postitati 11.03.09 18:42
Siis kas kui ma ASR nupust seda välja tahan lülitada, kas mul peaks hakkama armatuuris ka mingi tuli põlema, et nüüd on see väljas???
altz1
Registreerunud 13.03.06
Auto: V8tt
postitati 11.03.09 19:38
1) Ei pea süttima tuli.
2) Mida sa ASR nupust tahad välja lülitada? Veojõukontrolli? Siis tavaliselt süttib vastav kollane märgutuli jah.
Erkiito
postitati 11.03.09 19:43
Mhmm mul hetkel ei sütti midagi. ABS töötab aga ASR näitas ülalolevat viga. Ilmselt siis ikkagi ajuremont.
Tänud info eest.
