Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi 100 2,8 quattro
Pealkiri: audi 100 2,8 quattro (Vastuseid: 4 | Vaatamisi: 1882)
jippy
postitusõiguseta huviline
Registreerunud 19.01.09
postitati 12.02.09 15:48 Tsiteeri
http://www.auto24.ee/webcache_kasutatud/520/auto_php-id=579520-www_auto24_ee.html
tegemist siis sellise isendiga mida oskate ütelda, mis võib läbi olla ja vajaks vahetamist põhi vead nagu`?
hind ka kuidagi umbe odav
Audi100C2
Registreerunud 05.01.08
postitati 13.02.09 08:30 Tsiteeri
Algselt postitas: jippy
Kuidagi odav tõesti.
Võimalik, et lähiajal on vaja remonti teha, aga samas ei või kunagi teada - äkki on masin omanikul lihtsalt üleliigseks muutunud.
Tuleb proovimas/vaatamas käia.
Nokk kinni saba lahti variant....raske öelda kuulutuse põhjal.
Aiku
Registreerunud 03.04.04
Auto: AUDI A6 C5 1,8T 2000a.
postitati 13.02.09 08:38 Tsiteeri
No pildlit ju lausa näha ,et pidutiklotsid kulunud ,kompuuter õhtul jne.
Audi100C2
postitati 13.02.09 08:58 Tsiteeri
Hea tähelepanek, kohe esimese hooga ei vaadanudki :P
Ei tea täpselt kui levinud see viga on, aga võin lisada, et enda 100'l uued klotsid all ja ikka vilgub see tuluke seal ekraanil.
shalm
Registreerunud 01.06.08
postitati 13.02.09 09:16 Tsiteeri
Arvan, et kui osta plaanid, siis lase ennem kellelgi alt läbi vaadata-loksutada, saad teada, mis papp sillajuppide peale läheb, avastad ehk mõne õlilekke jne.
Kui mootorit pole remonditud, siis võib põletada õli nagu minu 93a V6 (klapisääretihendid).
Vilgub pidevalt Brake Lights tuluke kuna arvab, et vähemalt üks pirn läbi - tegelikult pole (mingi kehv ühendus vist kuskil?), häirivalt piiksub, muud midagi.
Hetkel ei meenu rohkem. Udutulede poolest on see konkreetne masin mu omast rikkam :D
[PHP: 14.3% - SQL: 85.7%]
