Pealkiri: A8 d3 veakoodid (Vastuseid: 5 | Vaatamisi: 3668)
Maku
postitati 31.01.09 19:40 Tsiteeri
A8 d3 veakoodid
Teab keegi mõnda kohta netis, kus uuema A8 veakoodide võimalikud lahendused kirjas oleksid?
Tänud,
Marko
Jürarrak
ac aasta auto 2008 võitja
Registreerunud 15.04.03
Auto: Some quattro GmbH Cars
postitati 18.02.09 14:28 Tsiteeri
http://wiki.ross-tech.com/index.php/Audi_A8/S8_(4E)
Sealt leitavad veakoodid ja ka kodeerimiseks juhiseid
Parem must minevik kui lilla tulevik
Maku
postitati 18.02.09 17:29 Tsiteeri
Audi A8 (4E) Battery Replacement
See on huvitav asi, et uue aku panekul tuleb see kodeerida.
This procedure details how to replace a battery in a vehicle using a separate battery management control module. See the separate instructions for models where the battery management control module is a slave/subsystem of the gateway.
The following procedure does assume you are using a battery supplied by VW/Audi, all necessary details for the following steps can found on the battery itself. Make sure to refer to the factory repair manual in order to fulfill all additional prerequisites.
[Select]
[61 - Battery Regulation]
[Coding - 07]
[Battery Coding Assistant]
* Enter the new Battery Part Number (10 or 11 digits).
* Enter the new Battery Serial Number (10 digits).
* Select the new Battery Vendor.
[OK]
[Do it!]
[Close Controller, Go Back - 06]
Your new Battery should now be coded and the Battery Control Module should be aware of the new Battery.
_____________________________________________________
Ramon, kus need veakoodid seal on?
Jürarrak
postitati 18.02.09 18:52 Tsiteeri
Vasakul pool tulbas on Fault Codes.
Lisan ka lingi :
http://wiki.ross-tech.com/index.php/Category:Fault_Codes
Muide, seal on infot alates A1st kuni R8-ni välja
Maku
postitati 02.07.09 19:43 Tsiteeri
Esmajärjekorras tegelen selliste veakoodidega:
19591 - Intake Manifold Runner Control: Lower Stop not Reached
P3135 - 000 - -
Freeze Frame:
RPM: 651 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 88.3 %
Duty Cycle: 20.7 %
Duty Cycle: 0.4 %
Temperature: 32.4°C
18308 - Coolant Fan Control 2: Open or Short to Ground
P1900 - 000 - -
Freeze Frame:
RPM: 651 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 9.8 %
Duty Cycle: 9.8 %
Duty Cycle: 9.8 %
Temperature: 32.4°C
Eks asume neti avarustesse. Samas, kui kellelgi on nendega kokkupuuteid olnud, siis igasugune abi on teretulnud.:) Igatahes ventikas hakkab kohe peale käivitamist karjuma nagu ratta peal. Autoks on 4.0tdi.
EDIT:
18080 coolant fan control 1 : open or short to ground p1672 -004-
No signal comunication intermittent
The left fan won't turn off the air con fan works and functions fine.
sounds like you may have the same on your S4. It's a small module up near the fan (on the A4). I'm not sure on price, since it was covered by warranty, but I'd guess $150-200 when it's all done.
Maku
postitati 13.10.09 20:54 Tsiteeri
Klotside vahetamine
Sellel autol ei saa piduriklotse ka niisama vahetada.:)
Adaptation
Channel 006: Pad Thickness
Enter the measured thickness of the new pads (excl. back panel), round down to the next lowest integer.
Range: 3 - 14 mm
Basic Setting
Open Rear Parking Brake for Pad Change
Prerequisites:
Connect a battery charger.
Cycle the Parking Brake ON, then OFF first.
[Select]
[53 - Parking Brake]
[Basic Settings - 04]
Group 005
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The brake pads are now opening.
[Done, Go Back]
Note: Check/Change Adaptation Channel 006 (Pad Thickness) after changing the pads.
Open Rear Parking Brake for Repairs
Prerequisites:
[Select]
Group 007
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Close Rear Parking Brake
Prerequisites:
[Select]
Group 006
[Go!]
[ON/OFF/Next]
The brake pads are now closing.
[Done, Go Back]
Function Test
Prerequisites:
[Select]
Group 010
[Go!]
[ON/OFF/Next]
The brake pads are now opening and closing 3 times.
Wait 30 seconds after the the brakes stop making noise.
[Done, Go Back]
Longitudinal Acceleration Sensor (G251)
Prerequisites:
System voltage at least 12.0 V.
Car parked on a level surface.
Do NOT move/rock car while performing basic setting.
[Select]
Group 020
[Go!]
[ON/OFF/Next]
The status of the Longitudinal Acceleration Sensor (G251) is now beeing displayed.
[Done, Go Back]
P. S. If you push pistons back by hand (without open electric part by vag-com) you broke servo mechanism of parking brake !
[PHP: 17.4% - SQL: 82.6%]
