Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - C4 TDI ei taha külmaga korralikult käivituda. (Mure lahendatud)
Pealkiri: C4 TDI ei taha külmaga korralikult käivituda. (Mure lahendatud) (Vastuseid: 11 | Vaatamisi: 2238)
JannA6
Registreerunud 17.02.08
Auto: A4 B5 2,8q 142kw
postitati 27.11.08 11:03 Tsiteeri
Tervist, et minu 96 a 2,5tdi 103kw on viimase kuu ajaga hakanud trikke tegema. Hetkel näeb auto käivitamine välja niimoodi, et kui eelsüüte märgutuli armatuuris ära kustub & seejärel starterit anda, siis auto lihtsalt sureb kohe välja. Käima läheb ta niimoodi, et lihtsalt tuimalt 15-20 sek starterit anda ning autot vägistada. Käivitushääl on täpselt selline, et nagu lubaks käima minna, kuid samas ei. Kunagi, pea aasta tagasi, sain ma autoga kaasa miskised eelsüüteküünlad. Sai need ära kontrollitud ( juhtmed külge, mõttes lugesin 5ni, ning olidki teised ilusad ja punased ) ning eile ka peale visatud, lootuses, et vanad küünlad kutud, kuid ei midagist, ikka sama jama. Teoreetiliselt on ju veel ka võimalik, et ka kaasasaadud küünlad olid surnud (kuigi nad punaseks läksid), sest miks muidu neid üldse vahetatud olid? Seega, kas on mingi kindlam moodus küünlaid kontrollida koduste vahenditega? Võib miski muu kah minu käivitusi raskendada peale eelsüüteküünalde? Soojalt läheb mootor paremini käima, kuid ka mitte ideaalselt poolest pöördest, vaid kusagilt teisest kolmandast pöördest. Diagnostikaabli lükkasin ma kah talle taha, kuid veakoodid puudusid, seega pumba tagasivooluklappi vms ei saaks nagu kahtlustada?
Jann @jääb audiklubiliste abi ootama
postitati 27.11.08 18:08 Tsiteeri
Tundub nagu küte langeks tagasi vaata kas õhumullid on selles läbipaistavas torus käivitumise aeg. Küünlaid on kõige lihtsam juhtmejupiga proovida. Ühendad küünlal juhtme tagant. Võtad mingi jupi juhet ühendad selle küünla külge. Teise otsa lased korraks vastu + klemmi mis on paremal kapotiall. Kui sädeleb siis on korras kui ei siis on läbi põlenud. Õige on muidugi testriga mõõta. (Taksitust peast ei tea kahjuks äkki mingi 1 oomi pidi olema.);)
JannA6
postitati 27.11.08 22:13 Tsiteeri
Nii, hetkelised katsetused testriga näitasid, et küünaldele ei jõuagi voolu peale. Ime, et auto üldse käivituda tahtis :) Sai kontrollitud eelsüüte releed (202 vist oli?), mis iseenesest paistis korras olevat. Seega, on tal kusagil miskit kaitset või midagist, mis saaks läbi olla?
equilibrium
Registreerunud 10.04.06
postitati 27.11.08 22:26 Tsiteeri
Kõigepalt peaks alustama temperatuuriandurist.
JannA6
postitati 27.11.08 22:37 Tsiteeri
equilibrium, ehk valgustaksid mind, et mida, kus ja kuidas kontrollida täpselt tuleks?
equilibrium
postitati 27.11.08 22:50 Tsiteeri
Diagnostikaabli lükkasin ma kah talle taha...
Sellega kontrolligi
Korraga kontrolli ka muud temp andurid.
JannA6
postitati 27.11.08 22:55 Tsiteeri
Point ongi selles, et diagnost ei näidanud mitte ühtegi viga. (või noh, airbagi tuld näitas, kuna sai kogemata eelpinguti lahti võetud, a see sai ära kustutatud)
Seega, arvuti nagu väitis, et kõik oleks iseenesest korras...
samru
Registreerunud 01.02.04
postitati 28.11.08 06:55 Tsiteeri
Algselt postitas: JannA6
Seda, kui tempandur valetab veakoodina ei näegi, näitab ainult ahela katkestust või lühist. Tembianduri vea tuvastamiseks peab natuke rohkem teadmisi olema kaabli taha ühendamisest ja veakoodide lugemisest. Eelsüüteküünalde kaitse peaks olema paremalpool jalamati all.
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 28.11.08 08:32 Tsiteeri
Temperatuurianduri viga peaks sellel masinal avalduma ka armatuuris tule mittepõlemises.
a6quattro
Registreerunud 27.12.07
Auto: AUDI A8 Quattro TDI
postitati 28.11.08 14:56 Tsiteeri
Temperatuuri andur lollitatakse ära(mingi jura sätitakse vahele) ja siis võtab ka sooja mootoriga küünlad järgi.Teine varjant süüdet sutsu varasemaks keerata.Samas ega need mootorid ju ka enam esimeses nooruses pole,kulumine teeb oma töö.
mack
Registreerunud 17.12.02
Auto: A6 3.0
postitati 28.11.08 15:05 Tsiteeri
Algselt postitas: a6quattro
temperatuurianduril tõmmatakse pistik tagant ära ja annabki sooja mootoriga ka voolu eelsüüteküünaldele peale.
JannA6
postitati 29.11.08 15:43 Tsiteeri
nii, oligi lugu selles, et tembiandur oli kutu. forsist uus, miski 80 krooni ringi maksis, ja asi jälle korras:) nüüd 1 komplekt miskiseid töötavaid eelsüüteküünlaid tuleviku jaoks kah varuks olemas. tänud kõigile, kes aitasid :)
[PHP: 10.8% - SQL: 89.2%]
