Pealkiri: veakoodide tähendused? (Vastuseid: 1 | Vaatamisi: 1410)
madu
Registreerunud 31.07.07
Auto: A8 D4
postitati 28.09.08 17:50 Tsiteeri
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
kellegil kogemusi antud vigadega?
ulith
Registreerunud 19.03.06
Auto: 80 b4 1.9tdi 94a/ VW G4
postitati 28.09.08 18:45 Tsiteeri
Põhjused mis tekitavad neid:
17536 - Fuel pressure/pump, injector(s), inatake/exhaust leak, AIR system, hose leak
17549- wiring, MAP sensor, MAF sensor
17538- sama mis esimene
18010- Battery was disconnected, battery discharged, alternator, wiring open circuit, fuse
[PHP: 19.4% - SQL: 80.6%]
