Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - makiga jama
Pealkiri: makiga jama (Vastuseid: 9 | Vaatamisi: 1471)
tankist0
Registreerunud 26.08.08
Auto: audi 80 2.0E 1989
postitati 05.09.08 16:00 Tsiteeri
makiga jama
mingi jama on et lülitad maki sisse siis nagu kõlareid pole taga heli ei ole aga kui suuremast august läbi sõita siis korraks mingit häält teeb ja jälle vait.
mis arvate mille viga on kas maki või kõllide?
ennem oli vastupidi sõidad august läbi siis jäi korraks vait.
olbert
Registreerunud 13.01.06
Auto: Golf IV 1,9TDi 4Motion Variant
postitati 05.09.08 16:04 Tsiteeri
mul oli kunagi kõlari juhtmest kruvi läbi keeratud ja siis see tekitas makile lühise ja lülitas võimendi järelt ära, kui kruvi kätte sain ja lühis kadus siis töötas taas laimatult.
kas sul ei ole kuskil äkist mingit lühist maki süsteemis? näiteks kõlarijuhtmetega kuskil?
Kuule mees, ega sa rahvastepalli ei mängi, kus sul mitu elu on!
www.alunaut.ee kõik alumiiniumi tööd (tegemist siis merealumiiniumiga)
tankist0
postitati 05.09.08 16:50 Tsiteeri
ei tea ennem töötas korralikult.
siis hakkas jamama kui auklikul kruusateel paar kilti sõitsin siis jäi vait ja siiamaani vait. vahepeal kui august läbi sõita siis korraks mingit häält teeb.
raunz
Registreerunud 27.09.04
postitati 06.09.08 07:49 Tsiteeri
Juhtmed oled ikka üle kontrollinud?
olbert
postitati 06.09.08 08:07 Tsiteeri
ma pakkusin, et kontrolli juhtmed üle!
tankist0
postitati 06.09.08 22:01 Tsiteeri
kontrollisin kõik juhtmed üle paistis nagu korras olevat.
olbert
postitati 07.09.08 06:42 Tsiteeri
vii siis makk remonti! kõige lihtsam viis teada saamiseks. kui makk on korras siis viga juhtmetes.
cornoyo
Registreerunud 09.02.07
Auto: s4 b6
postitati 07.09.08 06:53 Tsiteeri
Algselt postitas: olbert
Lihtsam oleks tegelt oma automakk sõbra autosse proovida, pole vast kuigi raske tegevus. Siis pilt selge kas viga juhtmetes/ühendustes, või makis endas.
Rauntz
Registreerunud 19.10.07
Auto: Audi 80 1,8 66kw 88a
postitati 07.09.08 09:07 Tsiteeri
Tõmba makk sahtlist välja, jäta juhtmed järgi ja raputa/koputa. Kui vahepeal heli tekib on maki viga kui mitte, siis jutmetes mingi jama.
tankist0
postitati 07.09.08 20:58 Tsiteeri
jah peab proovima
[PHP: 13.9% - SQL: 86.1%]
