Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - võimendi probleem
Pealkiri: võimendi probleem (Vastuseid: 3 | Vaatamisi: 1459)
siimp
Registreerunud 31.05.07
Auto: Audi A4 (B8) 2.0TDI
postitati 16.08.08 10:43 Tsiteeri
võimendi probleem
sai siis autosse (Audi A3 1996a.) veetud kõik vajalikud kaablid võimendi jaoks ja ostetud ka mingi Bolti võimendi ja Denveri woofer. probleem siis seisneb selles, et võimendi ei hakka tööle. sai testeriga kõik juhtmed üle käidud ja vool võimendini jõuab, samuti on mass korras. makist tuleb ka ca.4v rem.control välja aga kui auto käivitada, siis võimendisse jõuab 0v, kui juhe võimu küljest lahti lasta, siis ikka 4v. sai proovitud võimendit ühe tuttava subarus ja power tuli hakkab kenasti põlema, audis aga mitte. milles võib probleem olla? on kellelgi sarnast asja ette tulnud? kas rem.cntrl. vool ongi ainult ergastavaks vooluks mõeldud, mis annab hetkeks voolu (äkki võib see nõrgaks jääda)? makiks on kenwood kdc-w534ua
raunz
Registreerunud 27.09.04
postitati 16.08.08 13:52 Tsiteeri
Isegi kui remote oleks korraks, siis pidev vool peaks ju ometi jääma võimendisse.
Kust kohast Sa voolu võtsid? Praegu tundub küll, et vool on lihtsalt valest kohast võetud.
ranz
Registreerunud 29.09.02
postitati 16.08.08 14:22 Tsiteeri
Remote otsa peal peab siiski 12V olema, et võimendi tööle hakkaks. Tundub, et hetkel võtad sa makist remote lihtsalt valest kohas... kas maki tagant on see rem.cont sinine valge triibuga kaabel? või lihtsalt sinine? kui jah siis makil miskit viga, kui värvus pigem pruun valge miskis kombinatsioonis, siis too on hoopis teine asi.
siimp
postitati 16.08.08 14:48 Tsiteeri
Algselt postitas: ranz
kontrollisin üle ja tõesti leidsin ka teise sinise juhtme, millel oli ka mingi tekst sildiga peal, kuid mitte "remote control". võtsin siis juhtme sealt küljest ära, kus oli kirjas "remote control" ja panin selle teise sinise juhtme külge ning voila, töötab. ja tõesti 12v tuleb sealt pidevalt peale. tänud.;) (see Õige sinine juhe oli kenasti iso juhete vahele ära peidetud):D
[PHP: 19.6% - SQL: 80.4%]
