Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - külmalt ei käivitu hästi.
Pealkiri: külmalt ei käivitu hästi. (Vastuseid: 11 | Vaatamisi: 1245)
tanel63
Registreerunud 06.03.08
Auto: Audi 90 2.3 R5 100kW
postitati 19.07.08 03:04 Tsiteeri
millest võiks tulla see et kui auto päeva või paar seisnud siis esimest korda käima pannes tahab pikalt käiamist..autoks on audi 90 2.3
soovitage mida ära vahetada..olemas on doonor b4 2.3
Another Useless Deutch Invention
jokker
Registreerunud 10.07.05
Auto: A6 '96 ABK
postitati 19.07.08 16:57 Tsiteeri
Esimene asi, mis pähe kargab - pihustid lekivad. Kütuse surve vajub ära ja tahabki pikemat käiamist.
joyrider
tanel63
postitati 19.07.08 19:18 Tsiteeri
kas siis peaks kuskilt silmaga sealt pihustite juurest kh näha olema et bensiini välja ajab
tarmo
Registreerunud 05.01.03
postitati 19.07.08 19:19 Tsiteeri
Sisse ajab...
Mitte välja...
tanel63
postitati 19.07.08 22:03 Tsiteeri
võtan siis b4 ´ja pealt pihustid ja keeran enda autole külge..
Auto: 6x4x4
postitati 19.07.08 22:40 Tsiteeri
Esiteks võta kell ja piilu, palju sulle paagist peale uratatakse. Enne seda pole mõtet pritse ja muu kallale asuda :) Kuidas asi kävitub ~sooja mootoriga, ehk siis käinud, natuke seisnud ja üritad käivitada?
Edit: jutt jummala krussis, kuna joomine lorrapiga täiega pooleli :D. Vajadusel u2u :D
tanel63
postitati 19.07.08 23:34 Tsiteeri
kahjuks pole seda kella..sooja mootoriga on kõik normaalne muidu! Aga edu pudeli tühjendamisel..mille terviseks siis hävitate
mad5
Registreerunud 21.07.08
postitati 21.07.08 17:00 Tsiteeri
vaheta süütepool ära vaata mis siis teeb.
tanel63
postitati 22.07.08 20:59 Tsiteeri
Algselt postitas: mad5
pigem ikka pihustid kuna kui enne käivitamist lasta pumbal paar korda lüüa siis läheb ilusti käima
Mybestfriendmyself
Registreerunud 29.09.06
Auto: Audi 100 C4 2.8 Q
postitati 23.07.08 17:59 Tsiteeri
Kütuse surve ja/või pihustid.Audi puhul on kütuse surve mõõdik mootori töö probleemide puhul ära ütlematta tänuväärt abi vahend.
Võtad oma naise ka kaasa?Tuim oled peast või?Kes siis metsa puid kaasa võtab.
tanel63
postitati 23.07.08 18:12 Tsiteeri
jmh..varsti hakkan kaanele remonti tegema ja väike lihv ka...eks siis viskan pihustid ka ringi!
shoyer
Registreerunud 23.08.07
Auto: b4 92 2.3
postitati 28.07.08 09:34 Tsiteeri
mull kah enam vahem sama teema,,
külmalt käivitades lööb pöörded kohe 2000 (5-10sekundiks) kui auto soe siis see jama puudub aga soojalt läheb väga uimaselt käima.
[PHP: 37.1% - SQL: 62.9%]
