Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 Mootori temperatuur
Pealkiri: A4 Mootori temperatuur (Vastuseid: 7 | Vaatamisi: 912)
RemyM
Registreerunud 29.04.07
Auto: Audi A4
postitati 14.07.08 13:43 Tsiteeri
Selline küsimus,maanteel sõites pikemat otsa kiirusega nii 100km/h,viskab temp.90 kraadi peale ja püsib seal terve aja ( peaks ju alla ka minema mõne ajapärast) ,samuti ka linnasõite tehes on temp.suht kiirelt 90 kraadi peale tõusnud ,kas see on normaalne nii ? Hiljuti sai radikas ja tiivik vahetatud,koos muude tööde käigus.
Või peaks laskma diagnostikat mootorile teha, ettepanekud ,hea nõu oodatud.
jaakk
Registreerunud 23.07.07
Auto: Bmw 525i -2007, sedaan
postitati 14.07.08 14:17 Tsiteeri
Kõik oleneb ju termostaadist, minu autol on kogu aeg ka temp seier keskel ja ei kuku ta kuskile ka.
laurz
Registreerunud 30.12.05
Auto: b4TQ :D E39
postitati 14.07.08 14:28 Tsiteeri
Algselt postitas: RemyM
Kõik tip-top.Termostaat töötab ideaalselt.Läheb kähku soojaks ja hoiab temperatuuri:cool:
raunz
Registreerunud 27.09.04
postitati 14.07.08 14:37 Tsiteeri
Pigem oleks ebanormaalne kui temp hakkaks langema maantesõidul (ei tohiks langeda isegi talvel)
Mida soojem mootor, seda ökonoomsem (osadel uuematel autodel on temp isegi ca 100 kraadi juures soojast peast)
puna
Registreerunud 20.09.06
Auto: C5, Quattro, 4,2L
postitati 14.07.08 14:39 Tsiteeri
Ära muretse see on ideaalne.
laurz
Auto: b4TQ :D E39
Kas päris 100 aga jah 97 peal lööb ventika käima. tavaliselt 95 peal:P
RemyM
Auto: Audi A4
postitati 14.07.08 18:50 Tsiteeri
Algselt postitas: puna
No tore,kui see on ideaalne ,aga samas veel küsimus,temp.osuti 90 kraadi peal ja ventikas töötab ? Kontrollisin just spetsiaalselt,tulles pikalt sõidult,tõstsin kapoti ülesse ja vaatasin,seega et kui temp.on koguaeg 90kraadi ja ventikas on sees kas siis lõpuks on ikkagi hea nii ? Endal käis mõte läbi,et miks peaks ventikas töötama 90kraadi peal ?
juks11
postitati 14.07.08 18:55 Tsiteeri
kõik on nii nagu peab, ju enne kui me asju vahetasime oli midagi viga.
Ventikas hoiabki temperatuuri all ning lahutab kliimat, juhul kui kliima on peal.
Sõida ja naudi!
[PHP: 36.1% - SQL: 63.9%]
