Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleem A6 C4 97 kesklukuga
Pealkiri: Probleem A6 C4 97 kesklukuga (Vastuseid: 0 | Vaatamisi: 668)
estliiga
Registreerunud 16.08.07
Auto: BMW e39 520d touring ja VW GOLF MK2 1.6td
postitati 13.07.08 09:43 Tsiteeri
selline asi, et sai aku maha võetud ja pärast peale tagasi panemist enam kesklukk ei tööta aga signa läheb peale, võtmest ei saa uksi lukku keerata kuna varga kaitsmed ees.
Ega juhuslikult mingi keskluku resa ei ole võimalik teha vms.
EDIT: Sai kaitsmed ka üle vaadatud tundusid korras olevat
EDIT2: Sai proovitud, et istudes autosse ja vajutatud juhi ukse lukku ja uksed ikkagist ei sulgu, juhi ukse lukku panemise lüliti käib kuidagi kahtlaselt raskelt ka alla ja päris ukse sisse ära ei kaogi nagu teised ukse lukustid.
EDIT3: Jõudsin lõpuks vaakumpumbani, tundub , et see surnud kuna mingisugust häält asjake ei teinud.
kui palju rahaga peaks arvestama, et töötav isend soetada?
[PHP: 38.2% - SQL: 61.8%]
