Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Bensiinirõhu vaesus audi 200jal.
Pealkiri: Bensiinirõhu vaesus audi 200jal. (Vastuseid: 14 | Vaatamisi: 2015)
Rufhouse
Registreerunud 02.07.04
Auto: Audi 100 avant C2, Audi 200 20v, Audi A6 C7, Audi A8 D2
postitati 10.06.08 20:45 Tsiteeri
Jälle jama majas.Olen konsulteerinud paljude klubilistega,kuid ei ole siiani asjale lahendust leidnud-nimelt mure audi 200 (1988a)1b 147kw mootori bensiinirõhuga.Tühikäigul 6bari-pööretel langeb 4 bari peale(isegi kohapeal tuuritades langeb ca 4-5bari vahele.)
Seisma jättes rõhuks algul 2,5,peale natukest seismist tõuseb ise 4bari peale.
Mida olen proovinud:
*Pump-(korduvalt vahetatud)Praegu sai peale taastatud pump.Pumbas ei saa viga olla!,kuna peal on olnud 3 erinevat bensiinipumpa,millest üks oli võetud (korrektselt)töötava audi 200 pealt-kõikidega üks ja sama häda.
*Rõhu akumulaator-sai täna külge panud,ikka ei midagi paremat.
*Otse toide akult pumbale
Selline küsimus ka veel,et pumba peal on 2 klappi,see ülemine nö seen-see hoiab rõhku süütevälja keeramisel,aga mis on see alumine,kohe peale pumpa?
Äkki kellegil mõnda uut ja huvitavat versiooni pakkuda?
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 11.06.08 07:43 Tsiteeri
Algselt postitas: Rufhouse
Just see alumine klapp hoiab peale süüte välja keeramist rõhku. "Seen" on mingi leevendi vms.
Rufhouse
postitati 11.06.08 14:16 Tsiteeri
Any ideas?anyone?
Kaits
Auto: RS 6 Avant
postitati 11.06.08 17:29 Tsiteeri
Ma vist küll juba pakkusin seda varianti, aga:
Oled mõõtnud geneka pinget tühikäigul vs. pööretel? On võimalus, et vigase geneka puhul (harjad, kontaktrõngas) ei anna see pööretel korralikult pinget välja. Pinge langeb ja kütuse pumba tootlikkus kukub alla.
Kütuse trassid on korralikud: torud, filtrid puhtad ja ilma takistusteta? Tagasivool vaba?
Mis pumpa kasutad, tootekood?
Jääkrõhk (peale mootori seiskamist) võib mängida 2.5bar <-> 4bar, see ei oma erilist tähtsust. Pihustid avanevad 4.2bar juures, sinnani ei tohiks jääkrõhk tõusta, sest muidu jookseb trassist kütus silindritesse ja pärast ei lähe mootor normaalselt käima.
Rufhouse
postitati 11.06.08 19:02 Tsiteeri
Algselt postitas: Kaits
Geneka pinge on mõõdetud ja sellega ok(pööretel kui ka tühikäigul,kui tarbijad taga on 13,6-7v.Torudes ei tohiks asi olla,kui pumba pealt mõõta (sellest paagi kopsikust)Kahjuks teist manomeetrit pole,et nt mõõta külmkäivitus pihusti juurest.
Kas sellele pritsel on ka mingine tagasivooluklapp mis peab sulguma,kui rõhk liiga madal?
Kaits
Auto: RS 6 Avant
postitati 11.06.08 19:25 Tsiteeri
Tagasivoolu trassil ei ole ühtegi klappi. Tagant tuleb ette pritsepeasse, seal pannakse rõhk paikka, osa kütusest tarbib mootor ära ja ülejäänud (enamus) kütust läheb otse paaki tagasi.
kuuno
Registreerunud 23.02.07
Auto: audi200 2,2turbo/ 121 kw ja audi allroad 2.5,132kw.2003a
postitati 12.06.08 11:46 Tsiteeri
raamatust lugesin, et torustikus taga sillatala juures peaks olema mingi sõel vahel, minuomal seda ei ole . pumbapeal olev seen on mürasummuti ja sellest allpool olev julla on tagasivoolu klapp.
Rufhouse
postitati 12.06.08 19:20 Tsiteeri
Algselt postitas: kuuno
Tagasivoolu klapp?Kindel?
Kui nii siis üritan nädalavahetusel selle klapi välja vahetada.
Täna sai pandud küttefiltri ette otsa see manomeeter ja otse toide akult,manomeetri osuti lõi põhja(lagi 6,5bari tollel)ja hakkas vahelt väljagi piserdama.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 12.06.08 19:35 Tsiteeri
Tagasivoolu klapp on sul ju korras!
See oleks sel juhul katki kui sul langeks süsteemi jääkrõhk maha mingi paari minuti jooksul peale seismajätmist.
Tagasilla tala küljes pole ühtegi sõela.Selle asja nimi on rõhuaku.Seal sees on üks uskumatult pikk vedru ja taldrik.Kui nüüd see tagasivoolu klapp oleks kutupiilu ,siis käiaksid sa oma autot hommikul sa 2 minutit enne kui sealt üldse mingi pauk tulema hakkab ,sama teema ka sooja mootoriga.
Kaits
Auto: RS 6 Avant
postitati 12.06.08 19:50 Tsiteeri
Kunagi siin foorumis mingis teemas sai vaieldud ja lõpuks nimetasime selle pumbal oleva klapi tagasiLÖÖGIklapiks (fuel pump check valve). TagasiVOOLUklapp võib tekitada eksliku arusaama, et klapp asub tagasivoolu trassil. Seal aga teatavasti pole üldse mingit klappi.
Aga jah, sealt ma küll viga ei otsiks praegu.
Rufhouse
postitati 12.06.08 20:47 Tsiteeri
Praegu otsin viga sellisest vidinast:
http://www.sjmautotechnik.com/trouble_shooting/ecupic/fuelpic.jpg
Kuskilt vaja prooviks selline asi saada:P Oskab keegi öelda palju uus maksab?
kuuno
postitati 12.06.08 21:46 Tsiteeri
küsi sellelt numbrilt:56958106 toomas on nimi elab elvas ja teine number on .53995885 nime ei mäleta aga tema pani hiljuti 134kw tQ riiulile (otepäält).
Kaits
Auto: RS 6 Avant
postitati 13.06.08 15:42 Tsiteeri
134kW tq-l ei ole sellist regulaatorit. MC2-l ja 1B/2B-l on. Teistel on sama funktsiooni täitev regulaator pritsepea sees.
Rufhouse
postitati 15.06.08 17:09 Tsiteeri
Keegi veel teab,kus sellist jullat leida võiks?
Tänud sellele audiklubilisele(naissoo esindajale),kes eile õhtul helisatas ja üritas aidata:)...
Rufhouse
postitati 18.06.08 13:24 Tsiteeri
Nii,tänud kuunole,kelle käest rõhureg. sain,asi toimib nüüd jälle-nüüd veakoode kustutama!:P
[PHP: 32.4% - SQL: 67.6%]
