Pealkiri: Audi 1oo 92 a 2,3 mootor automaat (Vastuseid: 3 | Vaatamisi: 2025)
jan555
Registreerunud 08.02.07
postitati 09.06.08 17:37 Tsiteeri
Jätsin auto seisma ja enam ei käivitu pole sädet kompuutri test ei ütle ka midagi tulemused sellised
VAG-COM Version: Release 607.2-UD
Control Module Part Number: 097 927 731 N
Component and/or Version: DIGIMAT 0650
Software Coding: Diagnose VW
Work Shop Code:
6 Faults Found:
00281 - Vehicle Speed Sensor (G68)
03-10 - No Signal - Intermittent
00296 - Kick-Down Switch (F8)
35-10 - - - Intermittent
00300 - Transmission Fluid Temp. Sensor (G93)
34-10 - No Elaboration Available - Intermittent
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
00529 - Engine Speed Signal Missing
00299 - Transmission Range Program Switch (E122)
29-10 - Short to Ground - Intermittent
Control Module Part Number: 4A0 820 043 F
Component and/or Version: Klima-Vollautomat D05
Software Coding: 00060
Work Shop Code: WSC 02315
20 Faults Found:
00786 - Temp Sensor in Headliner (G86)
30-10 - Open or Short to Plus - Intermittent
00785 - Temp Sensor in Instrument Panel (G56)
00787 - Temperature Sensor in Fresh Air intake duct (G89)
00779 - Outside Air Temp Sensor (G17)
00799 - Coolant Temperature Sensor (G110)
29-00 - Short to Ground
00800 - Temperature Sensor at Fresh Air Blower (G109)
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
01271 - Positioning Motor for Temperature Flap (V68)
41-00 - Blocked or No Voltage
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
37-10 - Faulty - Intermittent
09-00 - Adaptation Limit Surpassed
01272 - Positioning Motor for Central Flap (V70)
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
01274 - Air Flow Flap Positioning Motor (V71)
01270 - A/C Magnetic Clutch (N25)
42-10 - Speed Deviation too High - Intermittent
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
00625 - Vehicle Speed Signal
27-10 - Implausible Signal - Intermittent
Kust viga otsida ?
Tänud ette
allparts
Registreerunud 16.03.08
Auto: Audi A4 99a 1,9td
postitati 11.06.08 18:13 Tsiteeri
minu autol põhjustas seda jama süütepool.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 11.06.08 18:55 Tsiteeri
Tõenäoliselt halliandur.
jan555
postitati 24.06.08 11:02 Tsiteeri
Jah halliandur oligi teine jagaja peal laenatud aga kust saab selle anduri kataloog ei näitanud .
[PHP: 18.6% - SQL: 81.4%]
