Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Deprecated: Implicit conversion from float 517151.99999999994 to int loses precision in /data01/virt4271/domeenid/www.audiclub.ee/foorum/viewthread.php on line 181
Eesti Audi Klubi foorum - B4 ja B3 ABS
Pealkiri: B4 ja B3 ABS (Vastuseid: 1 | Vaatamisi: 775)
martvo
Registreerunud 17.05.08
Auto: b3 1.8s ja b4 1.9td
postitati 06.06.08 11:51 Tsiteeri
B4 ja B3 ABS
Küsimus --> kas selline kooslus võiks hakata tööle.
Esisild B4 93'
ABS pump (loodetavasti on nimetus õige) B4 93'
tagasild B3 88'
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 06.06.08 18:07 Tsiteeri
esisilla veovõllide ja tagasilla veovõllide(quattro)-rummude(esivedu) hammaste arv peab klappima.
Muud takistust ei ole.
[PHP: 33.7% - SQL: 66.3%]
