Pealkiri: Alarmi ühenduste tegemine (Vastuseid: 18 | Vaatamisi: 1539)
Snowhite
Registreerunud 12.06.06
Auto: C5 S6
postitati 04.06.08 20:27 Tsiteeri
Mure,
auto audi a4 1996a universaal
oleks vaja siis alarmi paigaldamiseks vajalikke otste värve seal juhi jalgade juures.
või on äkki kusagilt linkida wire diagrammi?
otsind mitu tundi netist ja mitte ei leia midagi kasulikku.
wookie
Registreerunud 21.02.07
postitati 04.06.08 20:31 Tsiteeri
Algselt postitas: Snowhite
Aga kas need ei sobi?
http://www.autolib.diakom.ru/CAR/Audi/1996/A4/SYSTEM WIRING DIAGRAMS/
Snowhite
Auto: C5 S6
postitati 04.06.08 21:14 Tsiteeri
tänud viiekordselt
spcvnd
Registreerunud 30.06.03
Auto: A6Q
postitati 04.06.08 21:28 Tsiteeri
INSTALLATION POSITION
Modular: under the dashboard on the driver's side, above the connector support.
Compact: engine compartment, alongside the battery.
POWER SUPPLY
Positive: connect up in the fuse box with the fitting (+30) with eyelet Ø 6.
Negative: connect up with the manufacturer's fitting to the left of the fuse box, and relay support.
ENGINE IMMOBILISATION
Fuel pump: behind the footrest on the driver's side, on the light-blue 6-way connector, disconnect the green/yellow lead slot 3.
Starter motor: under the dashboard on the relay support, red/black lead slot 1, in a brown 2-pin connector.
Injection: under the dashboard on the relay support, red/dark blue lead slot 5, in a brown 6-pin connector.
Turbo diesel: disconnect the dark-blue/red lead (0.5 mm2) of the injection relay that can be identified under the dashboard on the dashboard on the driver's side in a dark-blue connector on the last relay on the right.
KEY POSITIVE (+15)
Connect up in the fuse box, under the dashboard on the driver's side with the fitting (+15) with eyelet Ø 6.
CENTRAL LOCKING
Negative-type controls. Identify the leads under the dashboard on the driver's side on the relay support in a purple 6-pin
connector. Grey/white lead, slot 1, for unlocking.
Dark-blue/red lead, slot 2, for locking.
For locking only, follow the connections given in enclosure 3.15.1.
TURNING INDICATORS
Connect up with the black/white and black/green leads in the group of leads coming down from the steering column.
DOOR PROTECTION
Behind the footrest on the driver's side on the connector support, identify a pale 6-pin connector, connect up with the brown/white
lead Ø 0.5 slot 2.
HORN
Positive electrical control on the black/yellow lead slot 5, under the dashboard on the relay support, in a yellow 6-pin connector.
BONNET AND BOOT PROTECTION
Bonnet: install a twin-contact push-button because the crosspiece is not earthed, since it is plastic.
Boot: connect up with the grey/yellow lead of the standard courtesy light, using a relay to swap over the polarity.
ei garanteeri, et 100% tõsi, sest kõik oleneb aastast, varustusest jne.
real1
Registreerunud 09.06.06
Auto: B3, B4, B5; B7, C4, C6
postitati 05.06.08 06:36 Tsiteeri
Kust see tekst võetud on?
spcvnd
Auto: A6Q
postitati 05.06.08 21:42 Tsiteeri
Algselt postitas: real1
internetist. :)
Snowhite
Auto: C5 S6
postitati 05.06.08 22:04 Tsiteeri
selline mure tekkis,
pärast alarmi paigaldust laseb autot käivitada alles mingi paari minuti möödudes alarmi maha võttes....
milles võib probleem olla?
on keegi varem sellist asja näinud???
teed uksed nupust lahti, kõik sisetuli läheb põlema ja kui süüdet keerad siis isegi katkestusahela relee tõmbab kui näppu peal hoida, on tunda aga käima ei lase lihtsalt panna. siis ootad, mingi mõttetu või seosetu aja
ja siis läheb lihtsalt plaks käima.
täiesti utooopiline probleem
alarmi kõik muud funktsioonid toimivad ka korralikult.
Snowhite
Auto: C5 S6
postitati 06.06.08 04:39 Tsiteeri
niiiiii
asi lahenes.
krt niii juhtub, kui kell 0200 öösel asjaga jänni jääd.
ei ole miskit,
tõstsin relee taga 87 ja 87a kohad ringi.
nüüd kõik okkkk
Riho88
Registreerunud 03.06.08
Auto: 100 avant 2.4D '94
postitati 14.06.08 12:40 Tsiteeri
nii, kaevan vana teema ülesse!
Ehk selgitad rumalale, mille releed on 87 ja 87a ?
Nimelt ostsin audi, millel kesklukk töötab aga alarm ei hakka röökima ja andurid üldse ei reageeri ja noh juhtmed on ka kuidagi "visatud" sinna, paluks abi korrastamisel :)
Snowhite
Auto: C5 S6
postitati 14.06.08 15:34 Tsiteeri
ee,
hetkel ei mõistnud sind,
87 ja 87a on ühe ja sama relee all olevad erinevad otsad.
sinu mure tundub olevat selline, et kas on miskit jäetud ühendamata, või on lahti lõigatud, sest auto kippus kogu aeg röökima.
ise ma sain lõpuks 4 erinevat paprit vaadates selle asja endal kokku. + veel helistasin kogu aeg tuttava "infoliinile", kes alarme paigaldab. lihtsaim moodus on selliste porride korda tegemiseks välja rookida ja korralikult uuesti panna.
Riho88
postitati 14.06.08 18:09 Tsiteeri
ok, mõistsin seda ümbertõstmist nüüd :)
nii, räägin pikalt, et endast targem mulje jääks :cool:
ostsin auto talvel [audi 100, C4 2.4D 1994 avant] esialgu tundus, et kõik nagu töötaks: alarm, keskulukk. Alarmi peale pannes piuksus, esitiibadele tagudes või uksi seestpoolt avades hakkas röökima - nagu peakski :) natuke hiljem enam ei piuksunud ja uksi avades ka ei hakka lärmama kah, ainult suunatuled hakkavad vilkuma ja salongis asuvad andurid ei ole üldsegi ühendatud.
Huh jube segane aga palun püüa mõista ja abi anda :) aitäh
Snowhite
Auto: C5 S6
postitati 14.06.08 18:16 Tsiteeri
tundub, et pasun on tagast ära?
ja siseandurid??
kas on infra andurid?
või kasutab mingit auto enda lahendust?
või siis veel mõtled seda, et kui uksi avad, siis ei hakka karjuma. kui seda viimast sis on miskit selle va sisevalgustuse kontrolliga vast viltu?
kui ise elektrik ei ole, ja kohe murest jagu ei saa, siis soovitaks tegelt kuhugi paigaldusse pöörduda. las uurivad.
mina endal enam ette ei võta seda va alarmi paigaldust.
maksan selle papi ja las väänavad ja käänavad.
mitte et tulemusel midagi viga oleks, ise jääks väga rahule sellise paigaldusega, mis mul lõpuks välja kukkus, aga no seda seljaväänamist ja sobitamist ja kontrollimist ja lollimängimist liiga palju selleks. sest vt kui on toodud auto,
sis võib kindel olla, et eelmine omanik oli debiilne ja keeras niipalju sitta kui vähegi võimalik. mul juba 5. audi peres ja kõigil on sedasi see olnud.
Riho88
postitati 14.06.08 18:31 Tsiteeri
nii pasunast jookseb üks juhe kuskile salongi ja teine ripub niisama :( - kuhu see ühendada + või - ?
sees peaks olema infraandurid - nagu pisikesed kaamerad ja nad on ühendamata, aga kuhu nad peaksid minema?
on mõtet ise üritada või loobuks ja kasutaks teenust...
spcvnd
Auto: A6Q
postitati 14.06.08 19:00 Tsiteeri
ikka mahuandurid(mikrid) või mikrolaineandur(nagu suitsupakk aint õhem).
kui 1 juhe on pasuna juures lühike lahtine, siis pakuks et see on algselt sinna samasse kruvi alla massi keeratud.
signa toimivust kontrollides tuleks enne vehkimist või luukide kangutamist oodata ca 1min või seni kaua, et LED hakkab rahulikult vilkuma, enne ei pruugi kõik andurid olla töösse rakendunud.
äss
ac aasta auto 2011 võitja
Registreerunud 23.03.04
Auto: 2x 1,8t ja masuudipress
postitati 14.06.08 19:07 Tsiteeri
Algselt postitas: spcvnd
osadel on see ka antenn (cobra nt.), mida massi väga ei ole mõtet panna.
Üldiselt on valveseadmete ja immodega ikka mõtekam pöörduda kuhugi kus teatakse mida teha - see ise aretamine võib kalliks maksma minna.
Riho88
postitati 14.06.08 20:37 Tsiteeri
nagu ikka mikker :D
oi aitäh lahke info eest! proovin ta massi ühendada - tegemist mingi "Mystery" alarmiga...
spcvnd
Auto: A6Q
postitati 16.06.08 19:14 Tsiteeri
Algselt postitas: äss
cobra compactil suurelt peal kiri COBRA ja on ka sellel "lahtisel" juhtmel punane ANT kiri peal ja otsas liimijunn. pealegi tuleb see õige paigalduse korral küljepealt välja mitte koos teiste juhtmetega. :)
aga selles suhtes on sul õigus, et selliste asjadega tuleks pöörduda viisakasse kohta, mitte päris suva urkasse hilisemate jamade vältimiseks.
Riho88
postitati 19.06.08 18:13 Tsiteeri
võtsin valjuka juurest juhtmed lahti ja puhastasin, alarm ruigab küll, kuid hirmus vaikselt, nagu teisest küla otsast, kus võiks olla volüümi nupuke? ;)
spcvnd
Auto: A6Q
postitati 20.06.08 15:58 Tsiteeri
Algselt postitas: Riho88
pasun hakkab surema ilmselt, pane uus.
[PHP: 27.1% - SQL: 72.9%]
