Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 2.o doch 101kw vajan abi
Pealkiri: Audi 80 2.o doch 101kw vajan abi (Vastuseid: 24 | Vaatamisi: 1682)
raksike
Registreerunud 26.05.08
Auto: Audi A4 1.8TQ
postitati 26.05.08 14:42 Tsiteeri
kas keegi oskab öelda mis käigukast läheb 2.0 doch 101 kw mootorile alla?
raksike
Auto: Audi A4 1.8TQ
postitati 02.06.08 22:36 Tsiteeri
kas siis t6esti ei oska keegi aidata?
Rain573
Registreerunud 17.09.05
postitati 03.06.08 08:20 Tsiteeri
Esivedu või nelivedu?
raksike
Auto: Audi A4 1.8TQ
postitati 03.06.08 19:27 Tsiteeri
esivedu
VipMan
Registreerunud 01.05.07
Auto: Audi A4 1,8 Turbo, Audi S4 4,2 V8
postitati 03.06.08 19:32 Tsiteeri
Mis aasta audi sul on?
raksike
Auto: Audi A4 1.8TQ
postitati 03.06.08 19:34 Tsiteeri
1991
VipMan
postitati 03.06.08 19:51 Tsiteeri
Algselt postitas: raksike
1991
Mis sul juhtus? Kas käigukast on puruks või tahad midagi muud alla panna?
On sul manual või automaat?
raksike
Auto: Audi A4 1.8TQ
postitati 03.06.08 20:58 Tsiteeri
kast jooksis kokku muidu oli manuaal algul kadus 3 käik ära
ja siis jooksis kokku:S
AudiMihkel
Registreerunud 12.12.07
Auto: Mitte audi
postitati 03.06.08 21:07 Tsiteeri
No kui nüüd loogikat kasutada,siis samasugune nagu ennem oli:)
Loogika & Taktika.
VipMan
postitati 03.06.08 21:12 Tsiteeri
Algselt postitas: AudiMihkel
Kõige lihtsam oleks see auto parandusse viia.
Ma arvan ,et seal teatakse seda paremini mis käigukast sinna istub.
pierre
Registreerunud 10.03.05
Auto: 90 7A
postitati 03.06.08 22:40 Tsiteeri
pagasniku luugi seespool on (kui on alles) tehasest kleebitud paber, ja seal on kirjas mis kast all on.
mootori tüübikood ja kasti tüübikood on üksteise järel, seal on saksa-, ning inglisekeelne viide ka olemas.
selle järgi võid romulatest otsima hakata, ei ole kindel, kuid arvan et sinna läheb ka mõnda muut tüüpi kast alla, isegi 2,0 85kW asi pakun....
edu.
raksike
Auto: Audi A4 1.8TQ
postitati 03.06.08 22:59 Tsiteeri
no lammerites olen käinud ja seal nagu kasti polnud öeldi et sihukese mootoriga audit pole neil sees olnud ja ei osatud öelda ka seda mis alla v6iks minna ku7skilt kuulsin jutte et 2,3 r5 100kw kast peaks ka alla minema
Rain573
postitati 04.06.08 06:23 Tsiteeri
arvan, et ei ole vahet mis b3 kerega audi kasti sinna paned. Ideejärgi peaksid kõik sobima.
VipMan
postitati 04.06.08 09:41 Tsiteeri
012300045PX- 5 Käiku manual Audi 80/90/Avant 89 1989a.
012300045AX- 5 käiku manual Audi 80/90/Avant 8A 1991a.
012300045BX- 5 Käiku manual Audi 80/90/Avant 8c 1992a.
Sinul peaks olema Audi 80/90/Avant 8A
Hinnad saad kätte http://www.audi.ee/varuosad/
pierre
Auto: 90 7A
postitati 04.06.08 11:07 Tsiteeri
Algselt postitas: VipMan
mind huvitaks kas Eestist kunagi üldse keegi on sealt mõne mootori või kasti ostnud? :D
vastus on kindel null.
need hinnad on seal selleks, et audimehed tahavad need jupid endaga hauda kaasa võtta. :P
revalist võid mõne liistu vms osta
VipMan
postitati 04.06.08 11:33 Tsiteeri
Seda küll :D
Ma tõin lihtsalt näited mis kastid on ja kui palju nende eest revalis küsitakse. Kindlasti on võimalik saada kasutatult neid kaste.
raksike
Auto: Audi A4 1.8TQ
postitati 04.06.08 16:17 Tsiteeri
selle bagasnikuluugi peal polnud seda s:(ilti:
raksike
Auto: Audi A4 1.8TQ
postitati 04.06.08 16:20 Tsiteeri
ja revalist vaatasin oli see kast 43057.00 ma arvan et ma sealt ei osta aga äkki oskab keegi veel pakkuda kust seda kasti saada?
raksike
Auto: Audi A4 1.8TQ
postitati 04.06.08 17:28 Tsiteeri
leidsin mingi sildi tagatiivalt seal oli kirjutatud GETR. 6A ____ AXD
Janis
Registreerunud 10.08.04
Auto: Subaru
postitati 04.06.08 17:43 Tsiteeri
http://www.varuosakeskus.ee/?mis=varuosad teed päringu ja jääd vastust ootama
raksike
Auto: Audi A4 1.8TQ
postitati 04.06.08 18:39 Tsiteeri
seal on maru kallid need jupid:s
raksike
Auto: Audi A4 1.8TQ
postitati 05.06.08 07:39 Tsiteeri
aga kas keegi ei oska öelda kas 2,3 100kw kast läheb?
VipMan
postitati 05.06.08 09:42 Tsiteeri
Leitsin E-bayst ühe
serxx
Registreerunud 31.03.03
postitati 05.06.08 11:38 Tsiteeri
http://www.varuosa.ee/
Suht kaasaegne ja korralik romula, asukohaga tallinnas, järvel.
ELS kuller toob kohale ka kui vaja.
Hetkel näitas kahte 2.0 kasti, hinnaga 2118,64
Mis mootoriga auto alt, seda muidugi ei tea ilma täpsemalt järgi uurimata.
raksike
Auto: Audi A4 1.8TQ
postitati 05.06.08 17:59 Tsiteeri
ahah aitäh
[PHP: 45.5% - SQL: 54.5%]
