Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 98.a. A6 tuletüüblid
Pealkiri: 98.a. A6 tuletüüblid (Vastuseid: 3 | Vaatamisi: 1057)
Heigosan
Registreerunud 03.12.03
Auto: A6 Avant Quattro & 200 Turbo Quattro
postitati 22.04.08 14:47 Tsiteeri
Mure järgmine et pirni vahetamisel selgus et kogu reflektor liigub sees päris palju....oskab keegi öelda kas asi kusagilt lahti või on tuletüüblid seest katki?
Kas tuletüübleid saab eraldi vahetada või ainult koos tulega?
nitram
Registreerunud 19.11.07
Auto: Audi A6 3,0 V6
postitati 22.04.08 19:39 Tsiteeri
minu a4 oli kunagi sama viga, et reflektor lahti. Midagi katki polnud, lihtsalt tõmbasin "nõksti" oma pesadesse tagasi ja oli korras.
jottess
Registreerunud 28.07.03
Auto: Audi 80 (B4) 1,9 TDI; Audi A4 Avant (B6) 2,5 TDI; Audi A4 Avant (B9) 2.0 TDI
postitati 22.04.08 20:45 Tsiteeri
Sama siin- reflektor koos luubiga vibreerib konarlikul/ebatasasel teel sõites ning kujutan ette, et selline värelev valgusvihk võib üksjagu häirida vastuliiklejaid. Tulede kõrguse regulaator reguleerib nii vasakut- kui paremat tuld sama ampluaa ulatuses, seega kardan, et munakust väljas see reflektor olla ei saa. Reflektor liigub alt paremalt (parempoolne tuli) ehk siis suunatule kõrvalt. Kahjuks ei tea, kus asub regulaator- kas üleval või all. Kuna tule korpus on kinnine, siis on visuaalne kontroll ka raskendatud, et mis täpselt järele on andnud.
Autoks on Audi A4 Avant (B6).
Sarnane probleem oli kunagi ka Audi 80-el (B4). Sellel aitas reflektori munakule tagasi lükkamine.
laur
Registreerunud 14.09.03
Auto: A7 3.0 TFSI
postitati 22.04.08 21:34 Tsiteeri
Vaata seda, ehk saad ehitusest veits aimu ja leiad üles koha mis on lahti:
http://foorum.audiclub.ee/viewthread.php?tid=48237
Palju variante pole, üleval on kaks nö tuublit mis peaks idee poolest üsna jäigalt kinni olema, ja ilma kruvikeerajata sealt välja ei tohiks tulla.
All on jah see munakuga kõrguse regulaatori mootor.
[PHP: 54.2% - SQL: 45.8%]
