Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Jama B4-jaga.
Pealkiri: Jama B4-jaga. (Vastuseid: 0 | Vaatamisi: 961)
Audi80
Registreerunud 22.08.07
Auto: F103 Audi 60L
postitati 15.04.08 17:23 Tsiteeri
Jama B4-jaga.
Punased vead:
Hüdraulikasüsteemi rikked:
1) Pidurivedeliku tase alla normi.
2) Hüdraulikaõli tase alla normi. (roolivõimu õli)
3) Hüdraulikasüsteemi surve liiga madal.
Jahutusvedelik rikked:
1) Jahutusvedeliku tase liiga madal
2) Jahutusvedeliku temp liiga kõrge
Tervist. Mul on selline mure B4-jal ,et viskab põlema punase (!) märgi ning selle kõrval vasakul kohe jahutusvedeliku rikke punase märgi.Olen kontrollinud jahutusvedeliku üle.kõik on max piirides.Et kas asi võib olla selles et tosool sees ja auto seisis talvel nii 3 kuud ja sees oli tosool mis kannatab nii -40 c ,on kuidagi (paksuks) tõmmanud (minetea seda)? ja siis andur viskab veateate armatuuri.Samas vahepeal piiksub ja siis kaob jälle iseenesest ära,ning mõnikord jääb üldse undama.Siis kui auto välja suretada ja uuesti käivitada siis läheb ilusti tööle, aga väikse aja pärast kui äkilisemaid sõiduvõtteid kasutada siis hakkab jälle undama/piiksuma.Ning isegi niisama heastpeast ja neid kahte punast märgikest vilgutama või jäävadki põlema. Oleks tore kui oskate nõu anda,et milles see jamps seisneda võib.
[PHP: 43.4% - SQL: 56.6%]
