Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Esimesed gabariidid
Pealkiri: Esimesed gabariidid (Vastuseid: 5 | Vaatamisi: 1325)
Hannespoiss
Registreerunud 27.11.03
postitati 02.03.04 19:06 Tsiteeri
Esimesed gabariidid
Audi 80 1989aasta. Eesmised gabariidid järsku kadunud, tagumised põlevad. Oskab keegi öelda mis numbriga kaitsme all need on? Või on milleski muus viga?
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 02.03.04 19:16 Tsiteeri
Gabariidid on kõik ühise kaitsme all koos numbrituledega,nii et viga peab peituma ikkagi mujal.Pirnid oled ikka üle kontrollinud?
Markko
Registreerunud 25.11.02
postitati 03.03.04 07:25 Tsiteeri
Esialgne postitaja QUATTRO
kummaline, minul igaljuhul nii parem kui vasak esimene gabariit eraldi kaitsmete all
numbrit ei tea kuid igaljuhul oli 5A kaitse - eks ikka ükshaaval välja võtta ning vaadata
better luck next time
jorgen
Registreerunud 04.01.06
Auto: Audi 100 C4 1992 2.8
postitati 26.01.08 17:55 Tsiteeri
Väga loll küsimus aga kuidas pääseb C4 kerel esimeste gabariitide kallale? Niisama vaadates kapoti alla ei torganud küll midagi sellist seal silma. Peab midagi lahti lahti lammutama (??)- ei taha uskuda hästi samas.
priit
Registreerunud 18.09.03
Auto: Audi C4, Bora & Octavia
postitati 26.01.08 18:28 Tsiteeri
Algselt postitas: jorgen
Tule taga on keeratav kopsik, selle keerad ära ja siis H4 pirni all on väiksem pesa. Tõmbad välja ja vehetad pirni ära ...tagasi panek vastupidises järjekorras.
priitpoiss --> priit
jorgen
postitati 26.01.08 19:16 Tsiteeri
Algselt postitas: priitpoiss
Ei taibanud alguses nii alt otsidagi seda.. tänud Sulle!
[PHP: 47.8% - SQL: 52.2%]
