Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 19" veljed vs. madaldus?
Pealkiri: 19" veljed vs. madaldus? (Vastuseid: 16 | Vaatamisi: 2615)
Rockkk
Registreerunud 19.08.06
Auto: Audi A4
postitati 31.03.08 18:49 Tsiteeri
Nonii...uuriks veits ja kuulaks maad, mida räägitakse 19" velgede kohta või siis madaldusest.
Autoks Audi A4 (B5) 95 sedaan, plaanis siis seda koopa vahet kuidagi ära täita. Tekkinud on ka mõned küsimused, ehk keegi oskab ligikaudseid vastuseid pakkuda.
Variant 1:
Kui autole paigaldada 19" veljed, siis mis sellega kaasneb? Suur kütusekulu + Eesti teed oma halva korrasolekuga põrutavad kõvasti esisilda? Mis hinnaskaalasse 19" veljed võivad jääda?
Variant 2:
Kui madaldus panna, kas siis liiga jäigaks ei lähe? Hakkab rohkem armatuuri ja värki põrutama? Kas on mõtet kasutatud madaldust osta v.oleks targem tutikas komplekt võtta? Mis hinnaklassi see jääks?
Teeme nii, et verist teemat ei tee. Oleks meeldiv lugeda teemakohaseid vastuseid, mitte arvamusi.
oooo
postitati 31.03.08 19:01 Tsiteeri
19" velgede panekul on madalduse lisamine kohustuslik. Väga nõme välimus jääb muidu.
Ja velg üksi ei täida koobast, eks siis tuleb vastav rehv ka ikka sinna peale otsida.
Jäik jääb nii või teisiti. Pane alla, sõida ja kui sa nendega veel kuu aja pärast ka sõidad... siis sa oled üks kannatlik mees. :)
Rockkk
Auto: Audi A4
postitati 31.03.08 19:14 Tsiteeri
Okei, aga madaldusega on lood ka "mitte pehmed"? On kellegil klubilisel hetkel A4'l all madaldus? Tahaks üle kaeda.
oooo
uko
Registreerunud 11.01.08
Auto: Allroad(132 kiluvatti),Avensis (130 kiluvatti)
postitati 31.03.08 19:19 Tsiteeri
Kui sa paned 19" ilma madalduseta siis hakkab kumm täislastis koopasse st. rehv vastu plekki käima,kui peaks teel mingi lohk või muhk olema.ja kui sa paned 19" siis tuleb see rehv sinna velje peale paras püksirihm millest võid sa väga kergelt lahti saada,kuna need teed siin eestis ei ole just kõige paremad.tean sest sain oma 17" 225/45 tutikast talvekast tänu väikesele löökaugule lahti:(.aga eks sa ise tead.:D
Rockkk
Auto: Audi A4
postitati 31.03.08 19:21 Tsiteeri
Kordan, teema on enese harimise eesmärgil. Ei ole midagi ostnud, ega kavatse ka midagi uisa-päisa osta. Selge on 19" velgede teema. Nüüd sooviks kommentaare/kogemusi madalduse kohta.
oooo
Xippy
Registreerunud 29.05.07
Auto: Audi 100
postitati 31.03.08 19:23 Tsiteeri
Mina soovitan pigem madaldust. Isegi 17" veljed on küllaltki suured ning sikutavad parajalt, rääkimata 19". Kui veel panna 19" velje peale madala profiiliga rehv, siis sõit kulgeb nagu paku peal.
Muidugi ei ole 19" veljed odavad, rääkimata rehvidest sinna peale.
Seega siis soovitaksin mõõdukat madaldust (selline, et koopa ja ratta vahe oleks talutav ning päris kanalisatsiooni luugi taha ka kinni ei jääks.) Madaldus vedrud + amordid tulevad kokku odavamad ka. Kui finantsiga pole head lood võta kindlasti kasutatud. Endal olid eelmise auto all kasutatud ning omaduste (v.a madalus, kuna auto madalaim koht oli maapinnast ca 6cm kõrgem)poolest jäin väga rahule.
Eesti teedel on muidugi lood ka ilma madalduseta suhteliselt kurvad.
Kaaku
Registreerunud 11.10.04
postitati 01.04.08 10:21 Tsiteeri
Millest 19'' soov just? Miks 18'' ei sobi? Minu meelest üldse 19 tolli on vähe liikvel. 18+madaldus on ideaalne.
Põrutamine on harjumise asi. Oma 18 tolliste allapanekul kevadel oli tunne, et teed on umbes 10 korda kehvemaks läinud, nüüd on suva :). Aukude vahel laveerimine saab ka kiiresti käppa ja tuleb puht iseeneslikult.
Madaldusvedrud võiks võtta ikka uued. Ei ole nii meeletu hinnaga. Ca 2600 raha.
Velgede hinnad olenevad seisukorrast ja mudelist.
18'' saab 10 tuhandega kenasti kätte. Selle raha eest valikut ka täitsa on juba.
mihkel
Registreerunud 27.12.04
Auto: seat leon
postitati 01.04.08 20:23 Tsiteeri
Oma värskest kogemusest julgen mainida et Tallinnas on juba 16 tollistega pisut valus sõita praeguste löökaukude vahel kui mõelda kuidas see veermikule mõjuda võib... päris põrutav on võrreldes 14 tollise talverehviga, millega auto üllatavalt mõnusalt pehme tundus. Rehvi profiil on ka 55, mis pole iseenesest just eriti ``püksirihm´´. Aga eks ilu nõuab ohvreid ja kui rahulikult kulgeda mööda head teed, siis pole nurisemiseks põhjust.
A4 all tundub 18 või 19 tolli pisut liiga bling-bling minu jaoks, kui just näituse eksponaat pole. A6 jaoks tunduks asi juba palju parem :)
postitati 02.04.08 04:59 Tsiteeri
Usu, Viljandis saab 18-19" veljega millel madal rehv, VÄGA kehv sõita olema. Järgi proovitud. Keegi eespool ütles tabavalt, kui kuu aega vastu pead, on sul ahvikannatus.;)
Ise paneks ka heameelega 18" alla, kuid ainult välimus ei kaalu üles kõike seda, mis halvemaks muutub.
Dan
Registreerunud 05.11.03
Auto: VW Golf R Mk7; Audi A3 SB quattro, Audi 80 quattro
postitati 02.04.08 06:24 Tsiteeri
Algselt postitas: Rockkk
Minul on all tegelikult coiloverid mis peaksid siis madaldama rohkem kui tava madaldusvedru :P Aga ees peaks olema -50mm ja taga -40mm
Erinevad pildid -> http://nagi.ee/photos/Dan18/sets/26638/
Selle jäikuse kohta... Et siiani on nagu hambad veel suus :P ja pole nagu isegi ära tüüdanud see "raputamine". Eelmine aasta kui 17 veljed ostsin siis ei saanud küll aru, et väga suur vahe oleks olnud võrreldes 16 veljega. Teed otsis küll rohkem aga jäigemaks muutus suht vähe. Selge on see, et tavalise A4-ja vedrustusega ei anna võrrelda aga mina väidan küll et see 17" ja madalduse kooslus ei ole tülikas ja vastikult raputav! (rehv on mul 225/45 R17) Samas olen kindel, et 18 tollise velje kohta käib hoopis teine jutt kuna rehv jääb juba suhteliselt madalaks:)
laur
Registreerunud 14.09.03
Auto: A7 3.0 TFSI
postitati 02.04.08 06:38 Tsiteeri
Ma küsiks vahele A6 kohta. Tükkaega plaan juba suuremad veljed panna aga ei tea kas 18'' või 19''. Mõlemal juhul peaks vist kindlasti madalduse ka panema. Et kui hull see asi A6'ga Tartu vahel on? Lõhub auto väga ära v kannatab ikka sõita ka?
Reimo
Registreerunud 18.09.04
Auto: Peugeot 508SW, A4 B5
postitati 02.04.08 07:12 Tsiteeri
Algselt postitas: laur
nagu siin juba ka räägitud siis levinum on ikka 18".
Mul on nüüd siis juba mingi 2 kuud KONI madaldus om A6-l.Ei ole nii hullu midagi sõita.Eks ta ikka raputab aga ei midagi katastroofilist.
Natuke veel ootamist ja siis saab mu auto alla ka omale suverehvid koos 18" velgedega
:cool:
Kui 18"suvekad all siis tean täpsemalt rääkida kui hullult raputab :D
Rockkk
Auto: Audi A4
postitati 02.04.08 07:51 Tsiteeri
Dan i auto näeb väga hea välja. Tundub, et lahendan olukorra madaldusega. Hetkel siis 17"OZ all.
oooo
postitati 02.04.08 08:03 Tsiteeri
Eks oleneb auto suurusest ka. 18" B5 all ei ole päris sama tunne, mis 18" C5 all. Mina olen sõitnud 17" velgedega C4, B4 ja A8 all ja neid ei anna üheselt võrrelda. A8 all on 17" sama, mis B4 all 15". Eks rehv on ka muidugi 10% võrra kõrgem.
Igapäevaseks tänavasõiduks ma ei soovitaks A4 puhul üle 17" minna. Ilus lõpuni kodaraga 17" velg (mõjub optiliselt suuremana kui randiga velg) pluss 35-40 mm madaldust ja jääb väga kena. Samas ikka veel igati sõidetav.
Madaldusvedrude korral tuleks tingimata jälgida, et nii eest kui ka tagant jääks ratta ja rattakoopa tsentrid samasse kõrgusse. Et ei jääks nagu Kaaku'l nina nõmedalt püsti. :P Pigem olgu kasutatud, aga mitte sellised. :P
darkSlide
Registreerunud 11.11.04
Auto: Audi A4 1.8
postitati 03.04.08 14:22 Tsiteeri
Ega jah ilma madalduseta jääb ikka tangiks(endal all 17" 225/45). Eelmine suvi möödus ilma madalduseta, mind ei häirinud, et mingi natuke tank, tulemus oli SELLINE 19" on asi natuke masiivsem, niiet mõtle. Olnud endal all ka 18" korraks aga need enam ei kannata üldse ilma madalduseta, 17" saab hakkama!
Rockkk
Auto: Audi A4
postitati 10.06.08 10:58 Tsiteeri
Teema on veidi vana, aga torgin veidi siiski. Tahaks sõita mõne A4 B5 ga, millel on madaldus ja mingi 16-17" velg all. Ehk kellegil viljandimaal/ järvamaal või kesk-Eestis oleks võimalik enda autot tutvustada ja sellega veidi proovisõitu teha?
oooo
VipMan
Registreerunud 01.05.07
Auto: Audi A4 1,8 Turbo, Audi S4 4,2 V8
postitati 10.06.08 11:25 Tsiteeri
Mul a4-jal on 18´´ velg plus veel 4cm madaldus.
Sõidumugavus vanadel teedel on väga halb. Näiteks üle 100km/h on võimatu sõita (raputab ikka kõvasti läbi).
Uuel teel jällegi sõidumugavus 5+
[PHP: 40.2% - SQL: 59.8%]
