Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.3 100kw jamad:D
Pealkiri: 2.3 100kw jamad:D (Vastuseid: 5 | Vaatamisi: 1065)
killer666
Registreerunud 09.12.06
Auto: 89 2.3 coupe
postitati 27.03.08 00:01 Tsiteeri
2.3 100kw jamad:D
Niisiis tegin jälle suure vea vist ja hakkasin audi omanikuks:D
1988 audi 90 ja seal peal siis 2.3 100kw mootor..
Kui seisab vähe rohkem aega ,siis tuleb metsikult käiata....
Mootor käib vaikselt , tyhikäik on soojast peast 1100 pööret , aga jama veel see , et väga uimane on kaa..
gaasi andes teeb sellist hääkt , nagu 1 silinder ei käiks yldse..
kuigi katsetades , käisid k6ik. mootor ei suitse , aga tuleks justkui mingit vngu...
Kust alustada vea otsimist...?
bensu vist palju ei v6tnud
exess
Registreerunud 28.05.06
postitati 27.03.08 00:12 Tsiteeri
Alusta diagnostikast....
Pisike punane putukas
pierre
Registreerunud 10.03.05
Auto: 90 7A
postitati 27.03.08 01:00 Tsiteeri
mul on tunne et sul on seal rohkem kui 1 kala....
edu!
Krooniline
Registreerunud 19.03.08
Auto: Jeep GC; Volvo V70
postitati 27.03.08 09:08 Tsiteeri
2.3 kipuvad õlirõnad kinni jääma. mõõda silindrites surved ära.
killer666
Auto: 89 2.3 coupe
postitati 27.03.08 09:34 Tsiteeri
Algselt postitas: exess
jah mida iganes....
Algselt postitas: pierre
edu!
mulle tundub ka...
Algselt postitas: Krooniline
&lir6ngad nyyd kyll survet ei m6juta...
Pigem on teema kuskil pr´itses , muidu auto nagu ei suitsegi eriti , pigemon co2 paigast ära..
M6tlen , et see pritse peaks olema väga lihtne ja m6ni asjatundja peaks symptomitest kohe aru saama , kus see kala on
pierre
Auto: 90 7A
postitati 27.03.08 11:50 Tsiteeri
paar ideed:
http://foorum.audiclub.ee/viewthread.php?tid=31561&page=1
ja siis paar head diagnosti kohta:
http://foorum.audiclub.ee/viewthread.php?tid=27108#pid191821
http://foorum.audiclub.ee/viewthread.php?tid=4799#pid285024
edu!
[PHP: 36.7% - SQL: 63.3%]
